Old 28th March 2010, 05:33 PM   #1
raven is offline raven  Canada
Default popping sound marantz sr4001
i have marantz sr4001 av receiver, every time i turn the volume up or down there is kind of cracking sound on the speakers and if i turned it up to the max it shuts down with protect message. i thought it was speaker connection so i remove all speaker wires and plugged an earphone and its doing the same cracking sound thing on the earphone. It's working fine by the way if i'm only using tuner/ radio. i opened the receiver to look for any obvious burn or something and i dont find any so far. I have a service manual for this, but i dont know where to start. any help would be appreciated.
txs
Old 28th March 2010, 05:38 PM   #2
Speakerholic
Cal Weldon's Avatar
This is often a static build up on the volume pot. Get some antistatic spray and ask someone how to best use it. Strange that it doesn't happen on the radio though...
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th March 2010, 06:11 PM   #3
hi thanks for reply
this does this even when i'm turning volume through remote control,(volume knob on receiver is steady).And i quess i should had mentioned the circumstances leading to this problem: i had my ipod connected to aux input 1 ( i had this set up for about a year), and last week about half an hour of listening, i heard a series of popping sounds and my receiver shutdown with that red small led flashing near power button. since then this problem came.
Old 28th March 2010, 06:24 PM   #4
Speakerholic
Cal Weldon's Avatar
ok, then we'll have to leave it to those who know more. I wonder if you have some caps going bad?
Old 30th March 2010, 05:14 PM   #5
i tried to look for some bad capacitors and they all seem to look fine, no burnt parts either. And just an update, it also does popping sound when i change the input selection, like from dvd to cd to tape and also when i'm changing settings like from dts to dolby to stereo, turning off equalizer and surround mode.Also i just notice that there is also popping when i'm using tuner its just not too loud compared to other inouts. So basically whenever i change setting i have this popping sound, also the pop come in conjuction with every volume digit i change and goes loud as volume is turned up and it is coming from all speakers.
Popping sound after turn off? portreathbeach Chip Amps 20 1st March 2010 08:43 PM
Marantz MA-700...Popping sounds? Three Legs Solid State 6 8th March 2009 08:53 PM
woofer popping sound caw Chip Amps 3 14th June 2006 11:33 AM
6550 making a Popping sound? Zero Cool Tubes / Valves 4 7th November 2005 07:10 AM
occasional popping sound dsavitsk Chip Amps 6 4th May 2005 12:58 PM
Page generated in 0.09953 seconds (74.61% PHP - 25.39% MySQL) with 10 queries
