I am building a KrellClone KSA100-MKII amplifier and need help deciding on the power supply design. When you make recommendations try to keep within the following scope:
1) Overkill - Keep every part with the thought of "over designed" if it says within the chassis dimensions 2) Quality Number One Importance - I am not concerned with the price, I am concerned with the quality of each part 3) Internal Chassis Dimension 258mm W x 143mm H x 358mm D Does anyone have a schematic to help me choose the correct parts? What Transformer do you recommend? What are the "perfect" values on the secondaries? What Capacitors do you recommend? What Rectifiers do you recommend? Thanks!
#2 |
I just wanted to add the schematic I was using just in case it changes anything.
How does the schematic look? I bought the boards from Honk Kong, really nice quality boards with Gold Traces. Last edited by xerocomm; 19th March 2010 at 05:12 PM. Reason: Spelling Error |
#3 |
This is a bad sign, no response. I guess no one has spent time on this design in a while? Can anyone direct me to a forum that has recently built a KSA100 MKII?
#4 |
Krell KSA 100mkII Clone
Biased to 100W (aka 2.5A) you'd need 700VA/40Vac per channel minimum. Option 2 is biasing to full output, on 1000VA/ch. Preferred electrolytics are CG type big cans, 100C minimum, 125C if you can spare the extra dollars and cents. Superior rectifier bridge diodes are fast/soft recovery types, TO247 package.
Looks like Sponge Bob has killed another thread. |
#5 |
The subject of Krell clones and their construction has been well visited in another series of threads. You can use the search function to find the details.
In most cases people opted for the same capacity and quality as stock or better. My personal preference is to keep the capacity of the power supply at or lower than the de-rated thermal capacity of the output transistors. My last build (with Neil Kaye) for 100W class A/8ohm, was a 600W toroid with ~40000uF with 6 output pairs per channel. With fan assisted cooling each channel weighed #35... In this instance you have not provided enough info for anyone to make informed comments. For instance what goals do you have for this amp? Not deciding this up front will cause you a world of hurt later on... Some items for you consideration: Class A output power into what load? (idle current) Lowest impedance load (peak current) Class B output power? (rail voltage) Stereo build, or dual mono? (transformer capacity) Do you plan on using fans? (mass and volume) AFAICT your chassis is just large enough for internal passive cooling of a single ~50W channel for 8ohm use or stereo 50w if fans are used. If you make a stereo 50W amp, in addition to making beautiful music, it will be a very heavy space heater. They only get bigger, heavier and hotter from there. None of the above is about sound 'quality' per se, rather quality of engineering for the given task. You can select the 'best sounding' components once you know what values are appropriate for the task you are attempting. HTH Stuart |
#6 |
hello,im interested in building myself one amp,please tell me the site where you bought the boards,or if you have a spare kit for mer...thanks
#7 | |
#8 | |
takes to power at 100watts. Lowest impedance load (peak current)--4ohms, but all my speakers are 8 ohms. Class B output power? (rail voltage) -- Trying to stay at Class A. Stereo build, or dual mono? (transformer capacity) The Chinese PCBs are for two MONO main boards and four for each main board (each driver PCB has either 2 each 2SC2240s or 2SA970S). I attached a photo of the PCBs. Do you plan on using fans? (mass and volume)--I hope not. I read that fans break down easily and spread dust everywhere. |
#9 |
I meant 4 driver boards for each of the 2 main boards. 2 driver boards are either V+ or
V- oriented. You can use only 2 driver boards for each main board if you want a KSA50 setup. I really wanted to try for the KSA100 MKII setup. I want to "FEEL" the music in my bones. I am wondering if anyone might have a schematic and parts list for a workable power supply and where I might obtain a soft-start for this setup. |
#10 |
hi
ive read youre posts but,dont buy these boards thery are not ok for the task i have 2 pairs very well made,that were perfected here on diyaudio.com an i saw on ebay, look for it i will sell these for 100 usd free shipping, -they can take pwoer caps on the pcb ive built mine using 1x 2kw transformer ,and very good resistors 2sa1943 2sc5200 ,excellent choice ,buy the right one not that cr,p you will have problems and youll be forced to do it from the begining |
| KrellClone KSA100-MKII 1000VA toroidal transformer EUROPE GB | Fix | Group Buys | 77 | 20th January 2009 08:05 PM |
| KrellClone KSA100-MKII Heatsink+Fan EUROPE GB | Fix | Group Buys | 65 | 24th November 2008 06:40 PM |
| KrellClone KSA100-MKII 1000VA toroidal transformer for dual mono GB | stolbovoy | Group Buys | 33 | 16th June 2008 04:39 PM |
| Leach,Krellclone,GAS,SAE,PL400...??? | bra | Solid State | 17 | 14th February 2006 10:48 AM |
| FS: Aragon D2A MKII DAC with Outboard IPS Power Supply | konstantin | Swap Meet | 0 | 17th July 2005 09:03 PM |
| Page generated in 0.13561 seconds (82.12% PHP - 17.88% MySQL) with 11 queries |
