Old 27th March 2010, 01:58 AM   #21
wg_ski is offline wg_ski  United States
That doesn't inspire confidence that everything is under control. How do you KNOW that it stays in adjustment after 10 years of being moved around in an equipment rack? I like VI limiters - you hit Vbe and it folds back. No muss, no fuss.
Old 29th March 2010, 02:38 PM   #22
LAJ is offline LAJ  United States
Default What I think happens.
Over a period of time, the bias pots creep from their proper setting. That's why I ALWAYS cement, glue , or silicone them after making proper adjustment. And that keeps the uneducated from opening it up and "screwing around." Seems like none of the amps I've seen come from the factory with the pots secured.
Old 29th March 2010, 04:47 PM   #23
When bias pots creep, you get distortion. Then you go fix it. If they open, you get a LOT of distortion (class B or even C operation). Then you go fix it. If a current limit pot creeps, you might not know anything about it until the amp is on fire.
Old 29th March 2010, 05:09 PM   #24
Audio Junkie
Zero Cool's Avatar
I would really like to find a source for that goop the factories use. sort of a clear/translucent red or green gel stuff that stays somewhat tacky. I found one place specified something called "Glyptol Resin" which sounds interesting.
Old 29th March 2010, 09:46 PM   #25
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
I've seen nail polish type stuff used, and suggested.
AJ
Old 2nd April 2010, 09:29 PM   #26
I use one of those touch-up bottles of paint that are sold for stone-chips in car paintwork. Discontinued colours can be bought for pennies.
Old 29th January 2012, 07:03 PM   #27
Zoors is offline Zoors  Sweden
Default Adjustments of an EP2500
Does anybody have the calibration routine on the EP2500?
I can tell something is wrong with it, as the lower part of amp, the negative half is much warmer than the positive.
90 degrees C against 65 degrees C, measured on the four transitors wit an IR termometer. And it turns off after some half to one hour, 8 amp mechanical fuse goes home.
I am afraid of a current limit pot creeper... =)
I did the usuel fastening of rectifier bridges that get lose, making it a cooler.
But I need the bias procerdure and the current limit procedure.
BTW, is this a copy of a Crown amp?
/best regards,
The Source...
Old 30th January 2012, 06:53 PM   #28
Default Its a copy of the QSC amp.
One of your biases is off. Ther are two bias pots. I would be very careful adjusting them. A little bit goes a long way. Also they are crappy pots and go bad frequently.
Old 1st February 2012, 08:08 AM   #29
Either 90 or 60deg C are too hot if the amp is in idle.
This is a copy of a QSC RMX2450 so the calibration is the same if you match-up the components on the QSC diagram.
If the main 8A fuse is blowing, I suspect more than just calibration, possibly one side of the amp is down or the rail switches are misbehaving.
Behringer ep 2500 service .... sakis Solid State 6 12th March 2010 06:56 PM
So whats the real deal with behringer ep-2500 saabracer23 Solid State 27 26th July 2009 04:48 PM
Europower 1500/2500 or QSC GX3 for strong mid range? Brit01 Solid State 7 25th July 2008 07:28 PM
FT: Behringer EP-2500 Power amp saabracer23 Swap Meet 0 25th March 2008 12:39 AM
Page generated in 0.09307 seconds (74.38% PHP - 25.62% MySQL) with 10 queries
