1000W amplifier -- This is great schematic
Old 18th March 2010, 02:12 PM   #1
DigiSoft is offline DigiSoft
Default 1000W amplifier -- This is great schematic
I've found this schematic and I think it is awesome design. It is very popular project in Balkan region. The design is by boro.
What do you think about it?
Old 18th March 2010, 02:24 PM   #2
R.I.P.
1000W into 4r0 requires >89Vpk and >22Apk.
Do you think this amp connected to +-95V PSU can deliver that into a resistive load?
Have you any idea of the peak current demand of a reactive load?
Have you any idea what size of heatsink is required to keep this amp cool?
What precisely makes this design awesome
regards Andrew T.
Old 18th March 2010, 02:28 PM   #3
wg_ski is offline wg_ski  United States
The only way for that (or any other amp using +/-95V) to put out 1000 watts is to either regulate the supply or run 2 ohm load with a practical one.
I'm sure the amp would *work*, with possibly minor modifications. Expect about 700W. The probelm with simulators is the "Vdc" element, that stays at 95V regardless of what kind of torture you put it through. Real ones aren't so well behaved.
Old 18th March 2010, 02:43 PM   #4
Well I think it might work because it is designed by trusted designer. Why do you think it wont output 1000W at 100V. Then what V is needed for 1000W.
You all people just talk about every design that it is not possible to deliver that amount of power but none of you showed some good REAL 1000W designs.
If 100V is little then why do we use transformers at all? Why don't we make power amplifier directly from the mains 240V just we will stabilize it using capacitors and diodes. LOL
I mean come on people... there are 5000W amplifiers. What voltage do they use? with your math they should use at least 400V supply.
Old 18th March 2010, 02:47 PM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
Originally Posted by DigiSoft View Post
If 100V is little then why do we use transformers at all? Why don't we make power amplifier directly from the mains 240V just we will stabilize it using capacitors and diodes. ................
Because that would be incredibly stupid and dangerous !!!! Which is why even discussion of that topic is banned on the forum.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 18th March 2010, 02:55 PM   #6
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Don't forget this amp is designed for PA
Old 18th March 2010, 02:55 PM   #7
Then how can I make 5000W amplifier?
I DON'T NEED IT I just want to make it so I can show it everywhere and I can boast around.
Old 18th March 2010, 02:59 PM   #8
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Ok this is the 2nd schematic i have seen where there are 2 sets of driver transistors and the output bank is split into two sections. There has to be some problems with this type of design. each output section has to run slightly different. how do you balance the sections??
Old 18th March 2010, 03:02 PM   #9
Here 500W version of this one for 8Ohms.
This is something like parallel wiring. I think it is same if you put 2 in pair of those power transistors.
Old 18th March 2010, 03:12 PM   #10
AUDISOUL is offline AUDISOUL  India
AUDISOUL's Avatar
Hi DigiSoft,
I think you have also this pcb with that
1000W amplifier -- This is great schematicHide this!Advertise here!
Building a 1000W @ 8ohms class D amplifier from zero moro696 Class D 89 26th July 2016 07:06 AM
BGR Blazer X10 1000W RMS Monoblock Power Amplifier sifis_samos Solid State 23 31st January 2011 03:32 AM
Are the Dayton HPSA1000 1000W Subwoofer Amplifier any good? harrisni Subwoofers 0 2nd June 2007 04:53 AM
Class D Amplifier Power Supply Design -> 12,5 A @ +/-80V = 1000W selfservice Class D 22 1st September 2006 01:20 PM
about "1000W" car amplifier Dj BASS AMP Car Audio 64 24th August 2003 09:37 PM
