Old 17th March 2010, 06:50 AM   #1
Default any body have details of 450 watts TIP142& TIP147Transister amp
4 numbers of TIP142 &147 can deliver 450 watts rms is it true? if yes help me to build it...............
Old 17th March 2010, 08:41 AM   #2
Aldotin's Avatar
The answer is a big NO.
2 pairs (4 pcs) of TIP142/TIP147 is OK for a ~70W RMS amplifier.
Old 17th March 2010, 08:47 AM   #3
will u plz give me the details
Old 17th March 2010, 08:51 AM   #4
AUDISOUL's Avatar
Hi Friend,
Just for your known search the schematic by this board its i think very simple. I dont know where i founded this design
Old 17th March 2010, 11:08 AM   #5
Originally Posted by AUDISOUL View Post
Hi Friend,
total 10 transister ..............?
Old 17th March 2010, 11:42 AM   #6
sakis is offline sakis  Greece
sakis's Avatar
god ...... drugs is a terrible thing .....
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th March 2010, 12:02 PM   #7
ilimzn is offline ilimzn  Croatia
Actually, it is possible - using +-50V power supplies and bridge mode. Such an amp could provide about 90V peak into an 8-ohm load, equivalent to about 500W RMS.
It would, however, need many devices in parallel to satisfy SOA and cooling requirements, and of course, the output stage would never work truly optimized due to integrated resistors in the darlington package.
If it was a pure 8 ohm resistive load and the supplies were limited to provide 80V peak into it, and they were cooled to sub-zero temperatures, then maybe 2 pairs could actually produce 400W RMS :P
Old 17th March 2010, 12:31 PM   #8
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Hi Friend,
You could try sending a PM to member, isa_olcer, whose name is on the board !
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Darlington TIP142 & 147 power amplifier. Matthewong Solid State 10 28th February 2011 11:50 AM
Fountek & Peerless Design - Construction Details Inside! soundengine355 Multi-Way 12 6th August 2008 02:14 AM
cheap amp can tip142 and 147 be replaced by bjts homertooties Solid State 4 5th December 2005 12:28 AM
Why hi-power amp produce clearer sound & more details ... nina Solid State 113 4th October 2005 07:49 AM
Page generated in 0.10791 seconds (80.23% PHP - 19.77% MySQL) with 11 queries
