Hello,
I am on the way to design an amplifier for input signals coming from RCA and XLR connectors. I am wondering what is the sensitivity to target for those two inputs as my amplifier may provide 100W max. I am targeting something like x30 gain. Is it correct? I couldn't find any reference document for the maximum level acceptable in both case. So if you are aware of : - maximum level in both case - recommended sensitivity - maximum common mode voltage for XLR Any comment appreciated! Best regards Laurent |
#2 |
domestic use or commercial use?
For domestic use, we usually see sensitivities between 100mVac to 1Vac for full power. For commercial use, we usually see +4dBu to +10dBu.
regards Andrew T. |
#3 |
Maybe I can be more precise on my request.
As in put stage will be connected to RCA or XLR, I need to know if I must apply various attenuation according to the input selected. I am ok to have 1V for full power using RCA. Does it make sense to have 1V for fullpower using XLR (1V is differential in this case)? |
#4 |
Forgot this answer : it is for Hifi use at home.
#5 |
design your sensitivities to suit the outputs of your domestic sources.
regards Andrew T. |
#6 |
Yes, if it was for me alone, I would just do like that. But the aim is probably to make some of them and I would like to be sure it is compatible with any symetric/asymetric input.
When you say 1V, is it for RCA or XLR? |
#7 |
You want to make some of them? So you want to manufacture as a commercial design, yet you do not understand sensitivity?
If you are going professional / commercial you need to pay for design assistance. Perhaps the guys on this forum that help you can take a share of your profit? Or is this forum a free help-line for incompetent marketing men? |
#8 |
Couldn't guess it could be seen like that... It is not for business, I already have a job it is on RF not Audio... I know what is sensitivity, the level for a given power, max power in my case. I know electronic (I am IC designer), but I don't know the standards used for audio. And I may change my sources so I need to align to a standard. The question is on the max level to be encountered on XLR connectors, I have none of those items at home. Why do I ask here? Because it is DIY Audio a good place to ask questions on Audio. I have asked on a french site, but the response was unclear, less technical guys. When I said I would like to study an amplifier for my own needs, I proposed to share results (for free!) and I have been asked if it could support symetric input (some of my friends have Cello Preamp and they adjust the sensitivity with strap according to the input). So I am investigating it. But when I go to Spice, I wonder what is the maximum input voltage (should I withstand 2V peak voltage for my input differential stage or not?) I already asked some questions about triggers, differential input, valves, power supplies and got some answers. I read books and have some others. This last question was not offending for me. Do you mean I have to pay to have a technical information on a public forum? Last edited by Macleod; 16th March 2010 at 05:18 PM. |
#9 |
Take a 225 to 300mV rms sensitivity in RCA plugs.
For XLR, standard is about 775mV rms, with an overload margin of +20db, that is 7.75V rms.. |
#10 |
Thank you wahab for your inputs.
7.75V is high. Some attenuation may be necessary for that input. Will go on investigate that. |
| RCA/XLR input ? | dejanm | Pass Labs | 7 | 17th July 2007 09:37 AM |
| Help converting an XLR input to RCA connectors | chuck22 | Instruments and Amps | 6 | 28th July 2005 06:23 AM |
| Amp Input: XLR & RCA switching | Devil_H@ck | Digital Source | 5 | 29th May 2004 08:54 PM |
| RCA to XLR | ejmdiscos | Everything Else | 3 | 5th April 2004 02:44 PM |
| RCA to XLR | bmwrob | Parts | 7 | 18th February 2004 04:54 AM |
| Page generated in 0.11300 seconds (76.50% PHP - 23.50% MySQL) with 10 queries |
