Old 14th March 2010, 11:14 AM   #1
apexaudio's Avatar
Default 150W MOSFET Amplifier with IRFP250x2
This circuit is upgrade on BUZAMP from Elektor. Use only N-mosfets, with +/-50V DC give 150W on 4R load.
Old 14th March 2010, 11:22 AM   #2
latala is offline latala  United Kingdom
I am interested in your amplifier can you please give furthere details
regards Trev
Old 14th March 2010, 11:33 AM   #3
wahab is offline wahab  Algeria
BC550C have a too low VCE of 45V for the +-50V rails..
Use BC546B, they have a 65V VCE..
Old 14th March 2010, 11:45 AM   #4
apexaudio's Avatar
Thanks Wahab. I not made this amplifier since 1995. 2SC2240, 2N5551... also can be used.
Old 14th March 2010, 01:14 PM   #5
russel is offline russel  Europe
I think you may hit thermal stability problems. Use a compound mosfet and mount the drivers in thermal contact with the Vbe multiplier that sets the bias current.
Old 14th March 2010, 01:21 PM   #6
apexaudio's Avatar
BD139 is on heatsink with output fets for termal compenzation.
Old 14th March 2010, 02:29 PM   #7
apexaudio's Avatar
This two old modules (about 20 years) same circuit without curent limit, with BF422/BF433 and BUZ21x4 stil in use work on +/- 36 DC.
Old 14th March 2010, 02:35 PM   #8
What bias current do you use?
Old 14th March 2010, 02:37 PM   #9
apexaudio's Avatar
50mA
Old 14th March 2010, 03:00 PM   #10
OK, thats quite low for a FET. Lateral FETS usually need 150mA and Vertical FETS are run at 400mA. If you look at the transfer characteristics in fig 3 on the link: http://www.datasheetcatalog.org/data...rf/irfp250.pdf
You can see if you ran it at 400mA there is chance of thermal runaway.
Maplin 150w MOSFET regulation? Craig405 Solid State 59 4th March 2012 08:30 PM
150W mosfet final results sakis Solid State 15 8th May 2007 08:52 AM
MOSFET amplifier ash_dac Solid State 6 5th December 2006 08:55 AM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
Page generated in 0.08832 seconds (79.58% PHP - 20.42% MySQL) with 11 queries
