150W MOSFET Amplifier with IRFP250x2
The circuit I used has made some changes, because the temperature of 2SA1837/2SC4793 is too high, I want to reduce its current, but the CISS of IRFP260 is too large. I increased the first -level driver
Yes that would be interesting to know. I have some boards from a few years back that just say NX400 on the backside. They look like mono boards. I only see one input from the front. Is there any info on these or a thread? This may be it. Mine has 6 total outputs, 3 per side. I plan on using IRFP250s bc I have alot of them. How high can you go with rail voltages if you make changes to cap ratings?
