150W MOSFET Amplifier with IRFP250x2
Old 8th October 2012, 07:50 AM   #131
azlospux is offline azlospux  Zimbabwe
Hie Apex, i am in the process of building my Kelvin amp, is it ok if i use 2SC 5200 on my output
Old 8th October 2012, 08:19 AM   #132
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Outputs must be darlingtons.
Old 3rd November 2012, 08:12 AM   #133
wattaniya is offline wattaniya
hi apex sir,
can i use irfp260 for nx14?
if u don't mind pls share nx14 layouts in pdf.
Old 3rd November 2012, 07:34 PM   #134
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
I believe that all of APEX files are in jpg format.
File Type: jpg APEXNX14pcblayout NX14 pcb size 82,5x60mm.jpg (166.9 KB, 1448 views)
Chop your own wood and it will warm you twice
Old 4th November 2012, 02:56 AM   #135
thanks for the image 44250,
Old 4th November 2012, 04:44 AM   #136
44250's Avatar
85,2 x 60mm is a size of the pcb.
Old 4th November 2012, 04:52 AM   #137
thank u 44250.
Old 4th November 2012, 11:23 AM   #138
R.I.P.
Can we have actual PCB size printed onto the layout of every PCB we see posted on this Forum?
regards Andrew T.
Old 4th November 2012, 12:01 PM   #139
44250's Avatar
I donīt know what to say,for all APEX projects i have printed as "Actuall size" and havent any troubles yet. That was with HV23,NX14 (16),APEX PROTECT+CLIP PSU,APEX PSU7,APEX AX12...
Anyway here are some dimensions that i have found at forums here in Serbia and at diyaudio.com:
APEX 550w class B PCB size 110x105mm
APEX A75 LM3886pcb PCB size 53x25mm
APEX AX12 size 47,5x82,5mm
APEX AX14 PCB size 60x82,5mm
APEX B200 tda 7294 stereo/bridge PCB size 115x62,5mm
APEX B500 Component 220x52,5mm
APEX D14 PCB size62,5x82,5mm
APEX G100 bas guitar PCB size 260x95mm
APEX H900 PSU PSU PCB size 105x70mm
APEX HV23 PCB size 200 x 50mm
APEX HV350 PCB 200x50mm
APEX NX14 pcblayout NX14 pcb size 82,5x60mm
APEX ML3 Mic volume Tone Preamp PCB size 100x40mm
APEX Protect and Clip PSU PCB size 90x130mm
APEX PSU5 pcb 140x90mm
APEX PSU7 PCB PCB size 200x75mm
APEX A-class Shunt Regulator PCB 80x77.5mm
APEX X1 sub PCB size 60x50mm
That is all i have of written dimensions. When i come in that dilema,i usually take a measure of IC,relays or transistors components at jpg. and than adjust width and height of pcb if needed. My first print is usually at everyday printing paper so i can compare ic/transistor/relay pinout directly with layout just to be sure. Hope i helped at least a little bit...
Old 4th November 2012, 07:55 PM   #140
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 150W MOSFET Amplifier with IRFP250x2
Thatīs what I would expect from the wise DIYer. As I usually say, to the good listener, half a word is enough!
Max.
150W MOSFET Amplifier with IRFP250x2Hide this!Advertise here!
Maplin 150w MOSFET regulation? Craig405 Solid State 59 4th March 2012 08:30 PM
150W mosfet final results east electronics Solid State 15 8th May 2007 08:52 AM
MOSFET amplifier ash_dac Solid State 6 5th December 2006 08:55 AM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
