What to do with a 300VA 2x38Vac transformer?
Old 11th June 2003, 05:08 AM   #1
Huey is offline Huey  United States
Question What to do with a 300VA 2x38Vac transformer?
I just purchased a 300VA 2X38Vac Plitron Transformer from a friend. He had purchased it for a junior design project but got one that puts out a bit more voltage then he wanted (forgot about the square root of two...). Now he didn't want it so I took it off his hands.
Any suggestions for the sort of power supply / amplifier combination that would be best for this transformer? For the DIY amps I've been looked at (Zen4, Gainclone, ect) they want a transformer with quite a bit less then 38V, hopefully someone has a suggestion for me to get the most out of the transformer or at least build something that's decent.
I'm going to be combining the amp with a pair of AudioReview DIY speakers
Thanks for the input
Old 11th June 2003, 07:17 AM   #2
MBK is offline MBK  Singapore
Check, it may have dual primaries, then you can use the primaries in series and get 2x19V.
MBK
Old 11th June 2003, 09:49 AM   #3
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Build an amp and see how it sounds. You have to look for a suitable design to use that trafo though.
Jojo
Old 11th June 2003, 10:07 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Huey
You might be able to get away with an ESP P3a, have a look at this thread, a guy there has one running at up to 63V rails, higher than your traffo would provide
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 11th June 2003, 04:26 PM   #5
The 'traffo' (sorry didn't know the slang for it ) does have dual secondaries, the schematics at Plitron threw me off since it only shows it in series hooked up to 230V.
I'll also take a look at that P3A amp, thanks for the input!
Likely I'll be using it in series, so the schematic on the right but just 115 across the traffo.
Old 11th June 2003, 05:55 PM   #6
There's the schematic that was suppose to be above.
What to do with a 300VA 2x38Vac transformer?Hide this!Advertise here!
WTB toroid transformer, around 35v, 300VA+ mcshaggy Swap Meet 2 23rd February 2005 03:21 PM
2 x 300VA 24VCT Transformer WALTER BURKHARD Swap Meet 1 6th November 2003 02:32 PM
FS: 300VA, 35-0-35 ILP toroid transformer Possum Swap Meet 0 8th October 2003 05:15 AM
FS: 300VA, 35-0-35 toroid transformer Possum Swap Meet 2 12th March 2003 05:47 PM
Toroid transformer 230 V/ 2 x 50V 300VA peranders Swap Meet 0 6th December 2002 04:56 PM
Copyright ©1999-2017 diyAudio
