hi,
If i would like to try on this quasi-complementary circuit shown below,what rate of transformer should i choose? in a way of VA. The link of this circuit is as below http://www.sentex.ca/~mec1995/tutorial/xtor/xtor6/xtor6.html quasi1.JPG thanks. |
#2 |
A 20...30VA rated transformer with ~22V secondary will do the job!
Good luck! |
#3 |
how do u actually calculate that value?or by experience?
But the circuit label a +30V ,isnt it needs +30V? thanks. |
#4 |
If the amp is 10watt then you need a bit more in VA due to losses into heat in the heatsink. I usually allow 50% for that so I reckon a 15-20VA transformer would do the job.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 | |
Banned
A 10W amplifier usualy means 10 watt sinewave (RMS) power. But music is not sinewave, it has less power. A 10 watt amplifier with 50% efficency wastes 10 watts in heat. For an IC (chip) amp, transformer VA ~ 2 * amplifier watts is a guess. The amplifier will work. If it gets hot, we put in a fan and buy a bigger transformer for next one. If it's a hot day, maybe the transformer goes bang anyway, so often we make it too big, just in case. +30V is +30V, but transformer VA is ~. Approximate. w |
#6 |
#7 |
could a transformer with a rating 30V, 30VA be chose?
thanks. |
#8 |
after survey around the shop, i decide to buy a 24VA transformer with secondary voltage equals to +30V. Can it be?
thanks. |
#9 |
#10 |
sorry, i really not understand this. how could a 22Vac gives +30V?
ok this is my plan for the power supply part. I plan to use a +30V 24VA transformer and connect to a bridge rectifier(1N4007 will be use) and filter cap(not sure what value to put,any idea?) to get +30Vdc. Am i correct? thanks. |
| DAC Rate... | Big_Bill | Digital Source | 9 | 10th September 2009 07:09 AM |
| How would you rate the best class-d | ruaneg | Class D | 4 | 24th September 2006 11:26 PM |
| Estimate power transformer current rate? | vax9000 | Tubes / Valves | 3 | 5th May 2006 11:49 PM |
| Slew rate value | Luke123 | Chip Amps | 5 | 7th April 2005 12:30 AM |
| Page generated in 0.11674 seconds (80.65% PHP - 19.35% MySQL) with 11 queries |
