i have this amp it keeps blowing caps in the output part i think its the mosfets,its going to be a pain to take these clamps off.it comes on fine with the caps off its a blown mosfet i think. weird amp dosent even have fuses.
#2 |
Wrong design, The caps couldn't handle the current ripple. The ripple should reduced with more inductive line.
It need to use better or bigger caps or more inductive in the line. If these caps used as supply, it can be replaced with larger farads, but if as output filter, replace with SH caps (motor starting) or MKP caps. |
#3 |
caps do that when they see high ripple current, replace with higher voltage. Check the diodes make sure they are good. if the caps are in the pre ac section , on the dc side of the switching supply, add a big cap on the 12 supply.
it is hard to tell where they are from the pic. |
#4 |
hers the pic
| Fujitsu Ten @3000M amp doesn´t power up | sdoom | Car Audio | 17 | 3rd October 2009 09:17 AM |
| alphasonik class "d" 2400 watt amp... frizznied | ppia600 | Car Audio | 18 | 9th April 2009 03:55 AM |
| Alphasonik USA2150 repair | shaolinfox30 | Car Audio | 3 | 14th August 2007 07:07 AM |
| Predator/amp never worked. Please help | Session | Class D | 4 | 19th May 2007 02:08 PM |
| ADS PQ20 amp- anyone worked on? | GordonW | Car Audio | 1 | 24th March 2007 08:14 PM |
| Page generated in 0.08188 seconds (71.80% PHP - 28.20% MySQL) with 11 queries |
