Old 11th March 2010, 05:59 PM   #1
anli is offline anli  Russian Federation
Default jazz-amplifier
Idea, first picture: input (I3), NFB (via R11), and output-zero-adjusting (I2) are summing at Q5 emiter. It's SE in class A (I1).
Implementation (soldered and under listening now) - second picture.
Advantages:
- it's DC amplifier,
- high PSRR (not-regulated PSU is in use, output Vrms is about 0.55mV),
- high current (and, as a result, good frequency characteristics) in the bottom mosfet gate chain,
- linear input ("ALPS-ready") - no preamp is needed,
- no need for input jfets to be stongly complemental,
- efficient (near max theoretical efficiency for SE topology).
Old 12th March 2010, 12:26 PM   #2
Originally Posted by anli View Post
...are summing at Q5 emiter...
- must be read as "at Q4 emiter", of course, in accordance with the first picture.
Old 12th March 2010, 05:25 PM   #3
Nico Ras's Avatar
At first glance this is a very elegant design. Well done Anli
Kind regards
Nico
Old 12th March 2010, 05:56 PM   #4
Nico, thanks! I'm listening to the amp fourth day, and still am very excited
Old 12th March 2010, 09:33 PM   #5
juma is offline juma  Serbia
juma's Avatar
Since i tried Mini-Aleph for the first time I noticed that HEXFETs sound worse when supplied with less than 20V Vds. I'm aware that you lowered PS voltage to decrease the total Pd of this amp, but it would be interesanting to hear it with at least +/-22V PS.
Otherwise, lovely amp, congratulations !
P.S.
When it comes to SE amps I always lust for a pair of good 16 Ohms speakers
Old 12th March 2010, 11:26 PM   #6
AKSA is offline AKSA  Australia
Andrew,
I agree with Nico. This is brilliant, I'm still figuring out some of the subtleties.....
I've noted your designs from the past. Some are in my schemats folder, you are 1 smart guy, perhaps you should keep your best ideas to yourself?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 13th March 2010, 04:39 AM   #7
I don't know a concrete schematics you are saying about, but, at any case, I think, the reason of such behaviour is simple - it is sufficient to look at datasheet plot showing input capacitance vs Vds. To cure the problem gate chain current must be increased, and the design permits such increasing (at my case the current > 30mA, but I just don't use mini-heatsinks for bjts and 9610). And, say, R10 just "takes" some heat from CCS.
Thanks!
Thanks!
...perhaps you should keep your best ideas to yourself?
Not being English native speaker I'm not sure I understand "keeping" meaning. Do you mean some kind of, say, amps kit producing? If it's the case - well, I'm far from business, and the only way I have ATM is to share own thinkings with music lovers.
Smooth Jazz Puffin Music 11 9th June 2010 03:51 PM
Jazz tune. GK Music 5 7th October 2008 11:57 AM
Latin Jazz... Bas Horneman Music 12 6th August 2005 04:56 PM
Fusion-jazz plysch Music 1 18th April 2004 08:27 PM
Jazz and Funk Marmaduke Music 10 8th September 2003 09:33 PM
Page generated in 0.09933 seconds (75.83% PHP - 24.17% MySQL) with 11 queries
