Old 11th March 2010, 01:53 AM   #1
Default Different between push-pull and quasi-comp?
hi,
As what i know, Quasi-complementary also works like push-pull amplifier. Just that push-pull is using 1 NPN and 1 PNP transistor. while Quasi-complementary is using 3 NPN and 1 PNP transistor. They both perform push-pull action. They sure have their own personality which i hope that someone can help me on this. What is the different if we compare both output? is it from a way of power? current?
Can someone help in this?
thanks.
Old 11th March 2010, 08:15 AM   #2
or can i say that quasi-complementary amplifier has higher gain?
thanks.
Old 11th March 2010, 03:50 PM   #3
nigelwright7557's Avatar
In my experience they sound pretty much the same but thats probably no recommendation with my hearing !
The quasi is a little odd in that one driver is a buffer and the other is an amplifying inverter. This can cause problems. I found in my design I needed a 220pf from base to collector on the inverting driver to slow it down a bit.
The quasi really comes from the days of weak or none existant pnp transistors.
I built a Maplin 225WRMS quasi in the 1980's and used it on a mobile disco it was really powerful and reliable.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 11th March 2010, 04:06 PM   #4
Originally Posted by motbuddy View Post
hi,
thanks.
Quasi-complementary is not _like_ push-pull, it _is_ push-pull. With silicon power transistors it's usually NPN Darlington pair for the positive and a Sziklai pair for the negative. The Sziklai pair is capable of voltage gain while the Darlington can only provide current gain.
Old 12th March 2010, 12:16 AM   #5
what is the advantages for quasi-complementary?The design is out just because of those days the price of a PNP transistor?
thanks.
Old 12th March 2010, 08:35 AM   #6
thanks.
It wasn't the price of the PNP transistor because it didn't matter how much money you had. The devices simply didn't exist yet. Some very fine sounding amplifiers were built with quasi-complementary outputs.
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 68 26th December 2011 07:17 PM
Quasi-comp bipolar amp schematics BlackCatSound Solid State 2 23rd January 2006 10:24 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
High power regulated, quasi-comp. Stocker Solid State 26 28th December 2004 04:13 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.08922 seconds (74.54% PHP - 25.46% MySQL) with 10 queries
