Old 13th June 2003, 12:24 AM   #11
MGR is offline MGR
Joan2
Aside from Alexan where can I get original ON transistors like MJ15003,MJ15004,MJ15024 and MJ15025.I have tied RS components but lately their price have increased so much.Where did you source the core for the Toroidal Transformer?
MGR
Old 13th June 2003, 08:41 AM   #12
StuartH is offline StuartH  South Africa
Hi Gareth
This is somewhat worrying. As far as Im aware, the company I work for uses quite a lot of components from Communica.
If you still battle to get parts, you can always try to get them as samples. People seem to have varying success with this, but its worth a try. And, at least you will know that ON semi wont send you fake components. Its a service thats worth using, so long as one doesnt abuse it.
Enjoy the long weekend! Youth day I think.
Cheers
Stuart
Old 13th June 2003, 09:07 AM   #13
AJT is offline AJT  Philippines
AJT's Avatar
MGR
i used to get my mj802/mj4502 and other motorola power transistors from variproducts/apson, since i have been out of the country for more than 7 years, i do not know if apson still exists.....the torroid core, i got in raon, lots of surplus ei cores (grain oriented types) with 2in center leg, nowadays i don't see them stores anymore....i have this real big power transformer with 2 1/4 in center leg and 5inch stack, primary at 220 volts, secondary at 120volts center tappped. the secondary is bifilliar wound to exactly locate the center for perfect +/- 85volts rail....this power transformer wieghs approximately 30kgs...
Transistors replacement funky2x Solid State 1 26th July 2008 12:20 AM
Replacement transistors vyju Parts 3 2nd February 2008 07:08 PM
Leach output transistors pooge Solid State 5 14th January 2005 09:26 AM
Leach - mixing Power Transistors Arco Solid State 7 15th August 2003 07:12 PM
Leach amp transistors supernet Solid State 11 12th March 2003 10:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
