hi can anyone help me with repairing my input board on my active powered sub woofer i have two with a very similar fault also i have the schematic if anyone needs for reference i have managed to get both the power amps working by replacing the output transistors several blown diodes and some heavy ceramic 5 watt resistors but the input panel has a slight fault it has 7 ne5532an op amps and also functions as the crossover, im no expert by any means but i think the main fault lies in the last opamp just before it plugs into the amp module i get a half clean half distorted type of sound when i patch an ipod into the xlr on the input module if i unplug the input module and inject signal (ipod again
regards Barry |
#2 |
cmon guys anyone help me troubleshoot this amp input module ?
#3 |
Can you post a link to the schematic, or scan it?
Are you sure the op-amps are getting the correct supply voltage? Have you examined the input board carefully under good lighting (as well as backlighting) and a magnifier (strong drugstore reading glasses will do)? There could be cold solder joints, even hairline cracks. |
| Active filter board GB | BobEllis | Group Buys | 1171 | 29th January 2012 04:01 PM |
| Active filter plus LM3886 - one board | MJL21193 | Chip Amps | 197 | 3rd November 2008 12:50 AM |
| Page generated in 0.07142 seconds (69.77% PHP - 30.23% MySQL) with 10 queries |
