Old 9th March 2010, 09:19 PM   #1
maouna is offline maouna  Greece
Default Sziklai power amplifier
what is your opinion about this amp??
driver and vas stage transistors are 2SD669A,2SB649A
Old 9th March 2010, 09:35 PM   #2
Joachim Gerhard's Avatar
looks like a D.Self design.
Old 9th March 2010, 09:37 PM   #3
nigelwright7557's Avatar
You might find Q70 needs a 100pf from collector t obase to stop oscilation on the output. I certainly found that in my quasi amp.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 9th March 2010, 10:01 PM   #4
yes its based on d.self's book. i have made this amp and now iam testing it but i am having a problem.
when i power it on ,theres a constant current of 500ma at one rail,regardless the input..
sometimes when i power it on,its ok but after turning up the volume a bit ,theres this constant current of 500ma .
whats this all about?
Old 9th March 2010, 10:06 PM   #5
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
which rail?
how much bias are you using?
do you have a scope to look at the output?
mlloyd1
Old 9th March 2010, 10:08 PM   #6
I would strongly suspect some kind of oscillation that triggers on a bit of output power (unless you get DC offset that draws current from one rail only). Once the oscillation starts it might not stop by itself. The amp needs stabilization. These kinds of output stages are prone to oscillation problems, so nothing surprising really. Emitter follower outputs are easier to stabilize, eventhough I haven´t succeeded completely myself in my own design.
Old 9th March 2010, 10:10 PM   #7
cbdb is offline cbdb  Canada
Is it oscillating? You will need a scope to find out, because the oscillations could be in the megahertz. Try the caps Nigel sugested.
Old 9th March 2010, 10:23 PM   #8
thanks all for your advice. its the negative rail i have connected the ammeter to,.i dont have a scope unfortunatelly..
dc offset is about 5-6 mV, and bias current is about 25ma.
the sound is ok at the output ,just this problem with the current.
the zobel resistor doesnt get hot .i suspect that when an amp is oscillating ,it drains alot of current but in my case its just 500-600ma
Old 9th March 2010, 11:00 PM   #9
Unfortunately you will not get very far in finding out what happens without a scope.
Try reducing R41 in steps down to 220R.
After that, try the folloing:
Try adding in series to Q67 emitter a parallel-circuit of the following three elements (don't leave one out, they're all important):
- a resistor smaller or equal to 68R (in steps, R_max=0.6V/I_q_VAS) in parallel with
- a diode (e.g. 1n4148) (kathode tied to rail anode at emitter of Q67 to prevent the emitter of rising above 0.7V over rail voltage) and also in parallel
- a capacitor of about 470pF to keep the gain on track at HF.
instead of a diode you could also use a transistor as self did in his book for current limiting. (guess that might be even more effective).
Try to measure the voltage over the emitter-Rs (R14 + R17) from emitter to emitter.
Check if there are jumps or hystheresis in the voltage displayed on your voltmeter, while setting the bias (no input signal). If the voltage is zero but the current through Q55,Q68,Q57 and Q70 is not -> pretty sure oscillation.
Old 9th March 2010, 11:14 PM   #10
jaycee is offline jaycee  United Kingdom
The PCB layout may also be a factor. Sziklai's are quite sensitive to this.
Your schematic doesnt show any on-PCB power supply decoupling. You will want this. Put some 220-330uF decoupling capacitors on the PCB, near to the output transistors. Bypass with 100nF.
a wonderfull sziklai sakis Solid State 198 25th January 2012 10:29 PM
Negative Sziklai timH Solid State 17 30th July 2007 11:13 PM
DC adjustable double-Sziklai Power Diamond Buffer mtlin12 Solid State 22 16th July 2005 07:11 AM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 07:55 AM
Page generated in 12.42897 seconds (0.96% PHP - 99.04% MySQL) with 11 queries
