luxman schematic, and advice needed luxman schematic, and advice needed - diyAudio
Old 9th March 2010, 03:25 PM   #1
monkeyworks is offline monkeyworks  United States
Default luxman schematic, and advice needed
I'm new here, thank you for making me feel welcome. I've acquired a Luxman lv 102 which I'm trying to rescue. I'm hoping somebody has a schematic to share with me; it would really help me effect this repair. Additionally, I mean to replace the BJTs and Fets (one of the large transistors blew during diagnostics) and cannot discover current replacements to the originals - hence another reason I need the spec docs. If anybody out there knows which BJTs and Fets I can use to replace or upgrade the originals with, please pass that along. I can forward the designations printed on each transistor if anybody wants a crack at this. Thank you in advance, vic.
Old 9th March 2010, 05:43 PM   #2
homemodder is offline homemodder  Portugal
Hi I have manual for LV103 which might be closely related if you cant find the 102. Luxman always used the best parts available so I wouldnt change much on them except if they are damaged. I suspect the mosfets you are talking about is 2sj115 and 2sk405, these you can still buy off ebay, not cheap as its dicontinued parts but its better to stay with originals as you may have to change compensation and biasing scheme if you use other parts.
Old 9th March 2010, 07:28 PM   #3
Thank you for your quick response. I would love to see the lv 103 manual. Can you email me a copy, or send a copy in the mail? The fets in the 102 are j77 and k214, not the same as in the 103. I hadn't thought to hunt for old stock transistors on ebay; I hope to find new product with comparable spec to the old. But I will check ebay now. Thank you again for your help and good ideas. vic.
Old 10th March 2010, 08:48 AM   #4
It is difficult sending manual as its 22mb, I dont think I can even email something so large so Ill try extract only the schematic but it seems its must different to your model then. Are those j77 and k216 fets used as outputs or something else, these you should also be able to locate from some ebay vendors at around 3 dollars a pop.
Old 10th March 2010, 02:35 PM   #5
I don't think the 103 manual is critical for me. The mosfets are part of the "driver circuitry" according to some poorly translated product literature. I found all 10 of the transistors for this amp on ebay (2 pair fets, 2pair matched BJTs, and one smaller pair BJTs)! They reside in a line mounted on the heat sink, in reflected pairs from the center. There is a single, very small transistor without markings mounted in the center on the heat sink and I have no idea what it is or what it's for. It has an offset metal clamp screwing it down on the sink, it's smaller than a kernel of corn. Any ideas?
Old 10th March 2010, 08:01 PM   #6
east electronics is offline east electronics  Greece
east electronics's Avatar
a bell rings that this amp uses only bjt no mosfets ...but i might be wrong .... make pictures and state types and numbers
be aware ...ebay and other sources are full og fake unknown maufacturer transistors there you need really to know what are you doing
here is some extra help
vintage amplifier repair/upgrade manual
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 10th March 2010, 10:58 PM   #7
Interesting now I would like to see a schematic, anyway the small transistor is for temperature compensation, I wouldnt mess with it if its ok, what are the power Bjts on the heatsink.
Every single one in this range uses mosfets so Ill be surprised if this one doesnt, the other models have bjt drivers and mosfet outputs but seems this one has mosfet drivers and bjt outputs.
Old 11th March 2010, 07:23 AM   #8
Bigred is offline Bigred  Canada
I use to repair Luxman under warranty and its been a long time but if IIRC the Luxman LV-102 uses 2SK214/2SJ77 mosfet drivers and 2SA1265/2SC3182 BJT outputs. These amps are quite a bit different than the hybrids.
Old 11th March 2010, 06:02 PM   #9
Bigred, you are spot on with the driver and output specs, that's exactly what's in my amp. I found a schematic/manual for the lv 101 here: Luxman LV101 Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics, and it looks to be identical in layout but of lower power. It uses different transistors, but the same fets. At least the ones mounted on the heat sink.
I hope I am even working in the right direction here (I never described my problem here). I get no output at the speaker terminals, or the headphone jack. I get good voltage at the big caps. The spec sheet describes a bunch of other transistors throughout the amp; do I replace them all? Thank you all so much for your help so far. vic.
luxman schematic, and advice neededHide this!Advertise here!
Luxman M03 schematic dkkarli Solid State 4 2nd March 2012 03:48 PM
Luxman A-007 --- Schematic? Oery Solid State 0 14th January 2009 06:59 PM
Luxman A-471-Schematic ROVSING Solid State 5 3rd November 2008 09:45 AM
Luxman 38FD schematic BigOx Tubes / Valves 0 10th May 2006 06:22 AM
Luxman L-100 Schematic needed Calebay Solid State 8 16th September 2004 06:36 PM
Copyright ©1999-2017 diyAudio
