Old 8th March 2010, 09:24 PM   #1
Default technics SU Z45
Can someone please help. i have inherited a technics stereo system from my grandparents. it all works well except the amplifier, (SU-Z45). when you adjust the volume, the levels jump up and down, and sometimes only one speaker at a time. if i fiddle with the control i can get it right, and it sounds amazing. is this the lack of use? is it a dust issue? please offer some advice.
it would be appreciated.
Old 8th March 2010, 10:28 PM   #2
nigelwright7557's Avatar
I would preplace the pots.
Some will suggest contact cleaner but I would recommend replacement.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 9th March 2010, 11:03 AM   #3
jaycee is offline jaycee  United Kingdom
Try contact cleaner in the volume pot first. It might simply be dust rather than wear.
A small warning - don't drive this thing too hard. It uses an STK2038 output module, and these have a habit of going pop. My own Technics SU-Z55 (similar internal circuit) did the same thing.
Old 9th March 2010, 11:16 AM   #4
wahab is offline wahab  Algeria
I did find a Technics SUZ25 (among others amps) recently at the local scrapyard,
and it doesn t work as well..
Does someone have a schematic of a nearby model?..
It use a high voltage IC containing the differential.
There s external components for the Vas and the output stage
devices.
Anyway, a bizarre design...
Old 9th March 2010, 11:24 AM   #5
It is probably AN7062 connected to STK2038... I think most of the SU-Z's had this arrangement.
I've got an extremely bad copy of the SU-Z55 schematic. Check for small signal transistors whose bases are connected to pins 8 and 11 of the AN7062 - they can die, unfortunately that usually kills the STK2038. They will probably be 2SA992.
Pin 10 should have about -15v on it, the power supply for this in the Z55 is dreadful - just a resistor and zener diode.
I didn't bother repairing mine - it cost me nothing anyway. Instead I used the parts and built an LM3886 based amp into the case. Later I scrapped it
Old 9th March 2010, 12:05 PM   #6
Thank you jaycee.
Yes, the circuit is surely the same, apart from the lower voltage
component in the ZUS25..
Ic is a AN7060 and power output device is a STK2028.
Bad thing is that this kind of amp has the tone control network
inserted in the feedback loop of the power amp, a bad habit
to spare some costs, so using a gainclone, you ll have to build
a passive baxandall , as the pots are antilogarithmic ones...
That s a poor design globally, and as you mention it, it doesn t
deserve to be repaired.
Funny thing is that these two last years, i did canibalize far more amps
than i did repair them !!...
By there, they are massively got rid off at the scrapeyard..
Technics SU CH 7 gfanini Solid State 0 3rd January 2010 09:57 PM
Technics SU-A900Mk2 OXAUDIO Chip Amps 4 2nd July 2008 09:26 PM
Technics SU-Z65 elec972 Solid State 0 10th February 2008 10:39 PM
problem with Technics SU-Z45 Power amplifier darshanwijekoon Solid State 3 17th November 2006 11:45 PM
Technics SU V85A yeti Solid State 0 28th January 2004 04:21 PM
Page generated in 0.08953 seconds (72.95% PHP - 27.05% MySQL) with 11 queries
