Old 8th March 2010, 08:40 PM   #1
Default Pioneer amp project
Well, I haven't been in here for a while but I've gotten back into fixing amps. I've got something different than my usual guitar amps I like to play with. This is a Pioneer SX-253R Stereo Receiver/amp. I'm still looking for a Schematic. A preliminary inspection shows no speaker output on either channel. The front display powers on. I hooked into the headphone output. A very small signal is there. If you turn the main volume up to 100% and run the headphone output into another amp and turn it up to 100% you can hear a very faint signal. I need a schematic. In the mean time I am going to remove the unit from it's case to make everything more accessable.
Old 8th March 2010, 10:32 PM   #2
nigelwright7557's Avatar
You can start by checking power supply voltages and fuses.
Some ohmage checks of output transistor C-E or S-D.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 9th March 2010, 08:02 PM   #3
Default voltage checks
I powered up the unit and did a few voltage checks. First, the 2 fuses on the board are good.
I checked the voltage across the 2 main power suplly caps(8200uF 63v)
They both have 53.7 voltage across them.
I found a M4017 voltage regulator. The Vout is 12V.
I checked voltages at the power transistors ( C4689 and A1804)
Channel 1.
C4689 B-C 34.9v C-E 34.9v
A1804 B-C 72v C-e 72v
Channel 2.
C4689 B-C 53.4 C-E 53.9
A1804 B-C 53.4 C-E 53.9
I would think the voltages from channel 1 and channel 2 should match.
I'm I right in thinking the voltages on channel 1 look odd.
Old 9th March 2010, 09:17 PM   #4
I think i would be checking the channel 1 output transistors next using ohmage checks on BC, BE and CE.
This is best done out of circuit.
Old 11th March 2010, 02:30 PM   #5
I removed the CH.1 output transistors and checked . Both are good.
Old 30th March 2010, 04:12 AM   #6
I can't offer advice with your amp, but would also appreciate a schematic or service manual if anyone has one My example works fine, except there is no bias current at idle - hence subtle distortion as it's thus running in pure class B mode! Erk. Now that wouldn't normally be a complex issue except that there's no manual adjustment provided for bias current, so a schematic would really help!
Cheers
Old 30th March 2010, 11:06 AM   #7
sakis is offline sakis  Greece
sakis's Avatar
best indication of working amp ( regarding the outpout stage ) will be to check all emmiters of output transitors to verify that are near zero volts ( measure emmiter to ground ) anything above 50-80 millivolt will triger the protection and no output
check this first ...then is the rest
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 30th March 2010, 11:31 AM   #8
h_a is offline h_a  Europe
h_a's Avatar
Channel 1 is missing the base voltage drop (CB=CE), so the outputs don't turn on at all. I would have a look at VBE multiplier/bias.
Seems to me Channel 1 has a large DC-offset (large imbalance between CE of complimentary outputs) that probably triggers offset protection of both channels.
Have fun, Hannes
Saburo project with elcheapo Pioneer gychang Full Range 39 18th May 2008 10:33 PM
Pioneer Project Fast1one Full Range 33 29th January 2007 03:56 PM
PE Pioneer 4" buyout project MPM Multi-Way 2 29th October 2004 06:56 PM
Page generated in 0.09750 seconds (74.14% PHP - 25.86% MySQL) with 10 queries
