Old 7th March 2010, 10:15 AM   #1
pointy is offline pointy  United Kingdom
pointy's Avatar
Default do mosfets suffer from magnetic fields
i have some buz80's that will be near to the output transformers in an amp build.
so i was wondering will they suffer from the magnetic field and if so how ?
Old 7th March 2010, 03:06 PM   #2
nigelwright7557's Avatar
I would have thought that induced currents would be minimal due to the output MOSFET's having a low inpedance o source & drain.
However care should be taken with longs leads to the gate connection.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 7th March 2010, 03:31 PM   #3
pointy's Avatar
i'm in luck my base fly leads run full away from the transformers. thanks !
passive components affected by magnetic fields? CarlyBoy Tubes / Valves 3 28th January 2008 07:09 PM
Tubes and magnetic fields SY Tubes / Valves 35 11th January 2005 07:02 PM
Would the active crossover suffer chris ma Everything Else 1 3rd July 2004 06:02 AM
toroid magnetic fields and monitors Shaun Perez Parts 3 1st January 2004 07:10 AM
Page generated in 0.05765 seconds (72.30% PHP - 27.70% MySQL) with 10 queries
