Old 7th March 2010, 08:09 AM   #1
Default Looking to replace 6800uF 50V filter caps
Any ideas? Would higher/lower voltage capacitors work?
Old 7th March 2010, 03:14 PM   #2
nigelwright7557's Avatar
What is the supply voltage and power of the amp ?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 7th March 2010, 03:58 PM   #3
pdul is offline pdul  Denmark
higher voltage is usually better
Old 7th March 2010, 04:02 PM   #4
As a rule of thumb: voltage should be the same or higher, never lower
Old 7th March 2010, 05:02 PM   #5
gain-wire's Avatar
These capacitors should be very easy to obtain at either Newark, DigiKey or Mouser. Never replace with a lower voltage unless you know exactly what you're doing in that application. Do not go more than 20% over the rated capacitance, or you risk drawing too much current out of the transformer and bridge rectifier.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 7th March 2010, 05:51 PM   #6
nigelwright7557: I don't know what voltage the power supply is (couldn't find it for some reason...the service manual labels it as B2+ and B1+). As for the power, I believe it is 45W to each channel.
I found these to at newark.
ILLINOIS CAPACITOR|688LBB050M2CF|Aluminum Electrolytic Capacitor | Newark.com
PANASONIC|ECOS1HA682CA|CAPACITOR, 6800UF 50V CAPACITOR | Newark.com
There is a single Elna cap at digikey that I know would work, but they're 15 bucks a piece. Would either of the ones I linked be ok?
Old 7th March 2010, 06:56 PM   #7
Steve Dunlap's Avatar
It would be cheaper to buy them here.
Aluminum Electrolytic Capacitors - Snap In
FS: 6800uF/63V caps, regulators, transistors, Br/Rects len_scanlan Swap Meet 2 18th January 2006 10:12 PM
Sprague Caps 16000uF/50V WALTER BURKHARD Swap Meet 1 25th February 2005 05:42 AM
4,700/50v ROE caps Peter Daniel Swap Meet 0 7th February 2003 05:50 PM
40x 4,700uF 50V power-supply filter caps for sale OddOne Swap Meet 4 17th January 2003 07:37 PM
Page generated in 0.07342 seconds (85.06% PHP - 14.94% MySQL) with 10 queries
