Old 6th March 2010, 10:47 PM   #1
nigelwright7557's Avatar
Default MOSFET simply blew up ?
I have made about 30 amplifiers using IRFP240/9240 MOSFET's
I aligned one of the 30 amplifiers setting the output dc offset and the bias current.
After about 5 minutes the fuses blew along with the output transistors despite running at a quiet level.
The blown transistors were very hot.
The other 29 amplifiers have had no problems at all.
I replaced the output transistors and the amp has run fine now for a week !
Does anyone know if MOSFET's do just sometimes pack up?
Or perhaps the bias current ran away for some reason ?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 7th March 2010, 01:04 AM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Nigel,
Is this about one of your commercial amps sold though EBAY etc??
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 7th March 2010, 01:59 PM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Did you notice any oscillation? Mos devices are very fast and can become an oscillator at many MHz if certain parts of the ‘internal circuitry’ are not dampened properly or may have bad contact. RF oscillation can appear as DC on a multimeter and can cause frustrating destruction.
All the trouble I've ever been in started out as fun......
Old 7th March 2010, 02:30 PM   #4
Did it Himself
richie00boy's Avatar
Maybe useful to put up a schematic (omit values if it conerns you). Maybe there is some marginal stability issue and you just happened to have all the "wrong" values with that one.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 7th March 2010, 02:43 PM   #5
The last time I had a mosfet amp blow up was one I was repairing and was a C-Audio something or other, it turned out I'd been sent fake mosfets. I just replaced them with expensive ones and it worked great.
Old 7th March 2010, 02:52 PM   #6
Originally Posted by poynton View Post
Nigel,
Yes but this one failed on soak test after about 5 minutes.
I always soak test the amps I sell for many hours to make sure they are OK.
Old 7th March 2010, 02:53 PM   #7
The VAS capacitor is 220pf which is much more than otehr people use.
It is probably overdamped rather than underdamped.
Old 7th March 2010, 02:56 PM   #8
Yes I replaced the blown pair of MOSFETs and it has been fine since.
I have kept this pcb for myself for playing at home. If there is any doubt about an amplifier I dont let them out to customers.
The MOSFET's are marked IRFP so I assume they are good quality from IR.
Old 7th March 2010, 08:26 PM   #9
CBS240's Avatar
My apologies for being vague, I was regarding to the mosfet itself outside of the CL, they can be great oscillators because of the lead inductance and the device capacitances which can resonate at MHz frequencies. Vertical types particularly. At 50+MHz range the lead inductance and PCB trace/layout can become problematic. Oscillations at this speed will pass right over the global loop and affect the bias stability of the mosfet. Most good mosfet amps have some sort of damping within close proximity other than just a gate stopper. If you find this type of instability to be a problem, you might try adding a gate Zobel filter to each fet. Maybe with a zero around 40MHz, say 27pf in series with 150R from gate to gnd. I find it can be very helpful in stabilizing mosfet followers, vertical types, hexfets and such.
Old 7th March 2010, 08:39 PM   #10
Before powering up for the first time I always put a scope proble on the output to look for excessive dc or ac.
I havent seen many designs with filters on the MOSFET gates, there is usually just a resistor.
simply vinyl? mpmarino Music 2 7th September 2008 02:57 PM
simply amplifier Hellboy Class D 0 21st January 2007 06:32 PM
simply baffling... tom1356 Multi-Way 1 23rd November 2003 06:39 PM
Page generated in 0.11126 seconds (79.73% PHP - 20.27% MySQL) with 10 queries
