Old 6th March 2010, 06:36 PM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default Ltp ...protection ????
I HAVE SEEN one yamaha schematic that features a classic AB design with an ltp in the front but there is a couple of 1N4148 in parallel ( one reversed from the other ) from input transistor base of ltp to the "output " transitor base of ltp
does any one knows the reason ???
is there to protect from something ???
thanks ....sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th March 2010, 06:50 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
maybe it prevents hard clipping.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 6th March 2010, 08:12 PM   #3
AKSA is offline AKSA  Australia
Protect the be junctions of the LTP from reverse bias when either the output goes to rail with a fault, OR the input exceeds 5Vp.
Not often used, but seen on sound reinforcement amps where ANYTHING can happen.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 7th March 2010, 08:56 AM   #4
Nico Ras's Avatar
This protection is to pass international EMC criteria. From memory, susceptibility is tested at 30V/m from 10kHz to 3 GHz. DIY does not care about these issues since compliance to regulation is not enforced.
Old 7th March 2010, 09:39 AM   #5
you can also add Zeners to +ve and -ve references to avoid overloading the input transistors.
regards Andrew T.
Old 7th March 2010, 01:21 PM   #6
sakis's Avatar
thanks everybody ...got the meassage
How are you Nico ???? very good to see you around
all the best for you and family
kind regards sakis
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
LTP question m6tt Tubes / Valves 3 16th February 2009 11:14 PM
LTP second grid SpreadSpectrum Tubes / Valves 9 6th August 2008 06:00 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
LTP using SSM2210 sss Solid State 0 12th December 2003 07:05 PM
Page generated in 0.06979 seconds (77.91% PHP - 22.09% MySQL) with 10 queries
