Interesting new devices
Old 5th March 2010, 11:08 AM   #1
jez is offline jez  United Kingdom
Default Interesting new devices
Check out this URL. Good to see something "new" for audio apps...
http://www.semelab.com/pdf/magnatec/...LF08NP20V5.pdf
Old 5th March 2010, 11:17 AM   #2
wahab is offline wahab  Algeria
The two "complimentary" devices in a single package is somewhat doubtful.
Old 5th March 2010, 11:40 AM   #3
woody is offline woody
Doesn't seem a good idea. Having them in the same package makes them harder to cool as a heatsink works best with multiple heat sources.
Old 5th March 2010, 12:38 PM   #4
east electronics is offline east electronics  Greece
east electronics's Avatar
presumably this will work perfect in Class D apps ...and probably there should be the target
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 5th March 2010, 12:54 PM   #5
krachkiste is offline krachkiste  Germany
I miss the possibility of adding source-resistors.
Though I admit I'd have to check again, why I think I might need them. Maybe for paralleling due to the...
...quite low current rating.
what am I supposed to do with 8Ap at 200V
Maybe usefull for a compact 2x30W@4R (2x60W@8R) Stereo with one of these per channel, but actually there are ICs for that, wich are even smaller than an amp built with these new devices, if size is the measure.
Maybe someone can find and point out an application, where these devices can make an advantage.
PS: in class D you don't really need linear devices, you don't need low threshold voltage. In fact you need the oposite for D - you want to have low leakege current and high gm for fast switching, and especially the lowest R_ds_on wich these devices here definitely fail to have. I have already seen combined p/n devices in one package for switching apps, though i don't remember wether they were powerfull enough.
Old 5th March 2010, 12:56 PM   #6
whatever the amplification class , they will surely find their way in
7.1 AV amps..
The manufactureres will then claim "high end mosfet powered",
while at the same time reducing the manufacturing costs.
Two hits with a single stone.
Old 5th March 2010, 02:45 PM   #7
ilimzn is offline ilimzn  Croatia
This is a lateral MOSFET which means it would be very inefficient in class D due to high Rdson. It is intended for linear operation.
Maximum power dissipation for lateral MOSFETs on which this part is based is on the order of 80-100W and it's mostly determined by the die size. The case used, if well executed, can manage 150W under the same conditions so it's not unreasonable to put two dies in there - it would be if they used larger 10A dies.
This device is really intended to replace the output transistors in a single pair design, which realistically limits the output power to some 50W or so. In such cases source resistors are not required (in fact, they may even not be desired) as the laterals already have low gm and rather large rail losses, and there is no need to fit them for thermal stability. That being said, a close look at the curves shows that the N part has higher gm than the P part (in common with older types that these are based on), so there have been designs where this was equalized somewhat by the inclusion of a source resistor in the N-ch part's source only, even though this requires a lot of consideration for changes in gm vs temperature.
Old 5th March 2010, 03:44 PM   #8
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Excellent devices for vertical deflection in CRT monitors.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 5th March 2010, 04:14 PM   #9
soekris is offline soekris  Denmark
Yeah, the market for new CRT monitors is a fast grow opportunity :-)
Søren
Old 5th March 2010, 06:02 PM   #10
Wavebourn's Avatar
Søren
Sure. High-end, Vacuum Tube monitors.
In milled aluminium cases, with golden knobs and buttons, golden RCA inputs, directional power cable.
Interesting new devicesHide this!Advertise here!
Precision devices...... Village Plank Multi-Way 10 14th December 2008 07:49 PM
Precision Devices tinitus Multi-Way 1 8th January 2008 12:57 AM
how to match devices -help- Stefanoo Pass Labs 7 3rd January 2007 06:39 AM
Interesting new (mis)utilization of class D devices itsmrdavid Everything Else 8 6th September 2005 09:32 AM
Output devices? Mr Evil Class D 42 12th January 2005 02:18 PM
