Check for oscillating amplifier
Old 4th March 2010, 11:41 AM   #1
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Default Check for oscillating amplifier
Hi mates!
I have read a lot about oscillating amps, what it seems to be the most common construction problem. I have been looking in the forum and on the net, and I couldn't find any place where is it explained the correct method to look for oscillation.
I have built some amps already, they were gainclones and headphone amps wich sounded quite nice and were not suspectfully hot. Despite I assume they are alright, I would like to check it anyway.
I have a 20Mhz scope. How should I test the amps? Should I just hook up the output to the scope and look for "something"? Wich pattern are we looking for? Any capture would be great...
And on the input side, may I short them or should I inject a test signal?
Any info will be gladly welcomed. As a novice, I have soooooooo much to learn from the "amps-masters"
Thanks in advance.
Old 4th March 2010, 12:17 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
Aside from obvious problems where you just look at the output and say, "holy cow, it's oscillating!", I find that with sine wave drive there is often some particular amplitude and maybe load, where you'll see just a bit of widening or fuzz on the top and/or bottom of the trace. It's usually near full power, but doesn't have to be. IMO, amplifiers that do that invariably sound different than amplifiers that don't. It's often the values of the output R & L that will cause or fix this.
Conrad
I may be barking up the wrong tree, but at least I'm barking!
Old 4th March 2010, 04:39 PM   #3
regiregi22's Avatar
Originally Posted by Conrad Hoffman View Post
Aside from obvious problems where you just look at the output and say, "holy cow, it's oscillating!", I find that with sine wave drive...............
Conrad
That's right where I am, in the problem of identifying obvious oscillation. What are we looking for in the scope? What are your methods of looking for oscillation?
Thanks for your quick response
Old 4th March 2010, 04:52 PM   #4
sumaudioguy is offline sumaudioguy  United States
sumaudioguy's Avatar
Default technique
Abuse the circuit like this- use your oscillator to select a sine wave first and square wave second. Turn the scope down in a darkened room and adjust trace to a fine clear line. Start with like 10kHz. Look at the waveform such that one single cycle pretty much fills the screen. Now all a load and look for ringing on the flat part of the square wave or like the guy says a "Fat line" anywhere in your clean trace. Zoom in on that fat part if one is seen. Now add loads with capacitance starting at 100pf and have a look. Then do 300pf and repeat. Then 1000pf. A power amp should drive a .1F and a headphone amp should drive a .01F easily. One of these may make the wave quite strange.
Old 5th March 2010, 01:44 AM   #5
fredlf is offline fredlf  United States
Send a message via AIM to fredlf
Hi all,
Coincidently, I have an Adcom GFA-555 that I believe is oscillating in one channel. I posted a picture of the trace today. You can pretty plainly see the "fat" clipping at the top of what should be a smooth sine wave.
I'll try and get a better pic next time I'm running tests.
cheers.
Old 5th March 2010, 02:26 PM   #6
regiregi22's Avatar
Originally Posted by fredlf View Post
Hi all,
cheers.
But what you show in the image seems to be a channel clipping. The amplifier cannot cope with the load and it clips the top of the signal.
I thought oscillation was a different thing.
Old 5th March 2010, 05:55 PM   #7
No, it's not just clipping. If you look at the picture of the trace full size you can see that it turns into a thick, "fat", fuzzy line. I admit it's a poor picture.
The amp had no load on it and was only running at half power (60vac).
Check for oscillating amplifierHide this!Advertise here!
oscillating PP EL84 amplifier Danko Tubes / Valves 29 28th February 2014 07:05 PM
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 03:30 PM
Hysteretic self-oscillating amplifier with constant switching frequency sovadk Class D 8 18th November 2006 10:44 AM
Single Rail full bridge self oscillating amplifier Anthony C Smith Class D 7 31st December 2005 10:08 AM
Another Amplifier Check Please zox2003 Solid State 28 7th April 2005 11:22 PM
