Old 4th March 2010, 08:04 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Distortion with "real" loads
Scott Wurcer, you wrote:
"I just confirmed that with an ordinary TEF the tuning of the drop in the degeneration resistors is totally messed up by having a phase to the load. I tried 5.7 Ohms and .9mH for a mag of 8 ohms at 45 degrees. Tuned to .009% degraded to .03%. Actually if you take just the thirds..."
in another place, where registration is impossible.
I confirm your findings. I am doing similar simulations, and later would make some measurements with dummy speaker load.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 4th March 2010, 07:45 PM   #2
Steve Dunlap's Avatar
Why did you not include the first sentence of what he wrote?
Old 4th March 2010, 09:43 PM   #3
Hello Pavel
Can you give the link of the complete Scott Wurcer post ?
I'm interest to read it.
Thank you
Bye
Gaetan
Old 4th March 2010, 10:42 PM   #4
wahab is offline wahab  Algeria
I did some sims using these load values.
Results are quite unexpected.
Conditions were : 10 KHZ 40V PP 8R and 5.6R + 0.91mH
The amplifier is a symetrical differential with no extraordinary
open loop gain and gainbandwith perfs, as it was designed for stability.
With pure resistive load, distorsion in a 1MHZ bandwith is 0.075%
Using the reactive load, the numbers collapsed to 0.0001% with
all high order harmonics vanishingly low.
I ll recheck all this a bit deeper.
I knew that reactive loads modify the distorsion s profiles, but not
to this extent..
Old 4th March 2010, 11:04 PM   #5
scott wurcer's Avatar
I was thankful that someone put together a sim that actually showed these effects. Frankly the circuits and models changed so often I didn't have the time to sort this out (some sets showed nothing). I will repeat this exercise was useful in that I had never thought of the effects of load phase on EF's. So I will repeat. The Early voltage modulation of Vbe is in phase with the output voltage and the Vbe modulation with current is is in phase with the current. They are both sources of distortion.
There was nothing there that would offend anyone.
2012, our time is running out.
Old 4th March 2010, 11:25 PM   #6
to this extent..
Hum..A sim issue..silly me!!
I did average over 200 cycles and the numbers are less distant..
0.0173% with resistive load and 0.00398 with complex load.
A 12db ratio, somewhat more realist..
Old 5th March 2010, 08:50 AM   #7
PMA's Avatar
I made a simulation for a certain output stage, at 20Vp. The load used is 2R + 0.5mH + (22mH // 460uF // 22R).
I am attaching load impedance curves and simulated distortion as a variable of frequency.
Old 5th March 2010, 09:50 AM   #8
PMA's plots show some interesting facts.
The load hits 4ohm 50degree phase angle at ~19Hz and ~130Hz.
At both these frequencies the distortion is neither at minima nor maxima.
At 50Hz the load phase angle is zero degrees and the resistive impedance is 24r
The distortion is at minimum driving this frequency. To be expected, with a resistive low current load.
The other zero phase angle frequency (330Hz) throws up an anomaly. Here the resistive load is ~2r0.
The distortion is near maxima into this resistive high current load. Why?
Why does the distortion appear to fall from this resistive maxima to the more reactive loading above 400Hz?
Referring back to the 50Hz distortion. Why is it appearing so much better than the 1kHz distortion? Has this amplifier been accidentally optimised for minimum distortion at low frequencies and low currents?
regards Andrew T.
Old 5th March 2010, 09:56 AM   #9
Seems that distorsion is inversely proportionnal
to the impedance.
I guess that a resistive load varying the same way
with frequency would yield about the same figures,
apart from a slight reduction in the distorsion delta.
A comparison with a resistive load would be insightful.
Old 5th March 2010, 10:02 AM   #10
There s surely a bit more NGFB at 50hz.
"dimmers" for inductive motor loads cliffforrest Everything Else 19 28th August 2007 08:40 PM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 12:32 AM
Real "cool" R-Theta heatsink simulation Gabster Pass Labs 26 15th April 2002 04:14 AM
Page generated in 0.11511 seconds (80.13% PHP - 19.87% MySQL) with 11 queries
