Hey everyone,
I need some advice. My roommate and I bought a Harman Kardon 930 amp towards the end of last year. About 2 months after we bought it, it blew a fuse. Once replaced, the new fuse blew in about 2 seconds. Today I finally had the time to take it apart and try to fix it. By disconnecting all of the boards from the power supplies, I determined that the two power supplies are fine, and that it is one of the boards that is causing the problem I reconnected one of the two (the one that drives the right speaker channel amp, the lights, and all of the other boards). It still works fine in this configuration. Ultimately, I have decided that it is either the left channel portion of the main amplifier board (maybe a capacitor died?) or that it is one of the power transistors. I just need advice on how I should proceed, and whether or not my logic in determining the problem makes sense. Thanks! |
#2 |
UPDATE:
I managed to isolate the problem to one of two things. While I was trying to isolate the problem, I powered on the amp and one of the capacitors on the aforementioned (in my first post) board literally exploded. It sounded much like a gunshot, leaving the innards of the capacitor all over the board, and even 2 feet away from the amplifier (I'm glad I'm ok). I think I'm going to order a new board (if I can find one), and replace the power transistors with the MJ21194G'swhich is also an NPN transistor, and was recommended as a good replacement for the original 2SC897's that the HK930 has right now. Does this sound like a good plan? |
| How can I fix this? | Tenson | Everything Else | 12 | 28th August 2008 07:54 PM |
| how do i fix my subwoofer | wanky | Parts | 2 | 5th January 2008 04:06 PM |
| Perpetuum-Ebner PE66: To fix or not to fix... | Grendel the Cat | Everything Else | 0 | 6th April 2007 05:37 AM |
| Page generated in 0.07122 seconds (66.48% PHP - 33.52% MySQL) with 10 queries |
