Evens C-500 amplifier ....opinions? Evens C-500 amplifier ....opinions? - Page 4 - diyAudio
Old 19th March 2010, 05:03 PM   #31
butch_vlad is offline butch_vlad  United Kingdom
This is the latest pcb review. Looks great can I have it .
Looks like Evens changed the position of some components. Q1 or Q2 was replaced with diodes?
No one has a PSU design available? Maybe I need to post in the Power Supplies section
Is R8 (39K) the feedback resistor? What exactly does it do?
Old 19th March 2010, 05:49 PM   #32
evens is offline evens  Thailand
Send a message via AIM to evens Send a message via MSN to evens Send a message via Yahoo to evens
Hi butch_vlad
Last C-500 I have changed from BF422/423 transistor is MPSA42/92 readily available.
Transistor Q1 is replaced by diodes to create a reference voltage to Q2 is fixed at 3mA constant current test, you must sound like that of a constant current circuit, both of which work well together and have instead.
R8 I use it with 39K values defines the rate of growth, you may reduce it down if they think the growth rate is too high gain, I think that part right.
Simple power supply for C-500
Old 19th March 2010, 10:37 PM   #33
Thank you for reply Evens.
The MPSA42/92 can be found easier than bf422/423 indeed.
After I finish testing the first prototype I will try the new design with MPSA42/92 and the new diodes.
Keep us posted with the modifications to the design, this amplifier is worth building and improving.
What do you think about changing Q10 and Q5 with mje340/350? How important are these transistors for the sound quality?....apparently the mje's are inferior to the bf422/423.
Good luck with your work!
Old 20th March 2010, 01:07 AM   #34
homemodder is offline homemodder  Portugal
The way to reduce noise like the hiss you say is present is to reduce the negative feedback network impedance, thus reduce R8, in consequence R4 must also be reduced by the same factor to keep the gain the same. Also R7 must reduce to same value of R8to keep LTP input balance. Another bonus is that this will improve the DC offset by the same factor that you lowered R8, R4 and R7.
Old 28th March 2010, 11:56 PM   #35
Finished testing the amp using 2sc5200 and 2sa1943
Sound improved a bit
The amp is stable.....small thump on power up
Will test to extreme to see if I can burn something
Evens can you upload the pdf file with latest PCB please? I want to try the diodes schematic.
Old 29th March 2010, 10:15 PM   #36
What can I say.....it has a powerful bass
Old 29th March 2010, 10:34 PM   #37
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
On this schematics you can see PSU. If you can, use separate wire for VAS suply.
Old 29th March 2010, 10:44 PM   #38
Thx Apex
This is the original schematic after C-500 is made. The protection and limiters are removed...but the rest is almost identical .
I've managed to obtain some PSU designs so all is good now.
Gonna start building another amplifier now...Evens C-500 is a good project... it has my approval seal
Old 17th June 2011, 04:57 PM   #39
Mhavskie is offline Mhavskie
can you post the pcb layout of Latest pcb c-500III
Old 2nd November 2011, 06:15 PM   #40
aliskamjad is offline aliskamjad  India
Can anyone give me the schematic of C-500 Amplifier
Thanx in advance
my E-mail id : aliskamjad@gmail.com
Evens C-500 amplifier ....opinions?Hide this!Advertise here!
threshold s/500 power amplifier swmpd Pass Labs 19 5th March 2017 10:19 AM
JL Audio 500/1 Amplifier Repair Help Audioguy564 Car Audio 10 27th August 2009 02:24 AM
Newish JL 500/1 amplifier FOR SALE Dominick22 Swap Meet 1 13th December 2007 02:38 PM
Hafler DH-500 Amplifier for sale joe carrow Swap Meet 5 13th August 2006 05:22 PM
Copyright ©1999-2017 diyAudio
