Until now, it is still a challenge, to create a solid state power amplifier with <100 mA quiescence current through the power output devices and sound quality like pure class A at the same time.
Unfortunately I haven't heard such an amplifier until this day. The same observation has also made Mr. Nelson Pass - go to http://www.passlabs.com/pdf/articles/seclassa.pdf (third paragraph) and http://www.passdiy.com/pdf/leaving_class_a.pdf But below a collection of topologies, that most likely could reach the very clean sound of class-A without any harshness. There are probably more of such circuit topologies and I want to know others (except Class D). What about your audible experiences - what you would say, which topology is closest to Class A regarded the sound? Thank you very much for your comments. 1) P.J. Walker Current Dumping Audio Amplifier" http://220.232.128.43/audio/quad405/...J%20Walker.pdf Quad 405 DCD mod3 - PCB 2) N.M.Visch "A Novell Class B output" Class B w/o crossover distortion (1975) 3) Yamaha's Hyperbolic Conversion Amplification (HCA) Circuit Yamaha's Hyperbolic Conversion Amplification (HCA) Circuit 4) NDFL = Nested Differentiating Feedback Loops New Cherry NDFL amp http://www.diyaudio.com/forums/solid...s-some-example 5) ERCO from diyaudio member "turnA_zpoint " http://www2.plala.or.jp/puthoff/MJ.html http://www2.plala.or.jp/puthoff/mate...ork_081030.pdf http://www2.plala.or.jp/puthoff/material/EXP_MK2_V2.pdf MJ Magazine (formerly Musen to Jikken) - Yearly Index from 1924 - 2009 wanted (Post # 11) Last edited by tiefbassuebertr; 3rd March 2010 at 01:53 PM. |
#2 |
Here the next circuit I have found: JBL's bridged T-circuit
http://www.harman.com/EN-US/OurCompa...tions/1091.pdf |
#3 |
Current-dumping (feed-forward) applied to a conventional Class-B amplifier topology (a number of variants are possible):
Current-dumping Class-AB Self Type-II EF O/P The darlington O/P version won't qualify as Class-A sonics, but variants that use a Class-AB Self Type-II EF output stage along with current-dumping get close to Class-A sonics. Also, it is possible to combine current-dumping (feed-forward) with the Visch Class-B topology, which should yield sonics which are comparable to high-end Class-A. |
#4 | |
Here various URLs with topologies, which all have one goal: to outwit the disadvantages of Class B: New Class A, Super-A, Non-Switching : need a revival ? Bootstrapped ClassA - ? New-Class-A ? (whats it mean) Technics Class A Bias Circuits Technics Class A Biasing New Class A, Super-A, Non-Switching : need a revival ? Technics Class-AA / Sandman Bridge Class AA Opamp Schematic Now AA is down? Classes of operation vs. sound quality Pass Patent 5,343,166 For me follow topologies seems to be closest to pure class-A (have a look also to the attached PDF): :: Audiotek 69 - [Technics SE-A1?] :: Power amplifier Here some papers about THD measuring procedures and effects by Class-B: ELECTRONICS & WIRELESS WORLD JULY1987 £1.95 Crossover distortion in class-B amplifiers Detailed tests on three modes of amplifier operation, including a non-switching class Btype, using the same basic circuit produce a fewsurprises. E. MARGAN : http://www-f9.ijs.si/~margan/Articles/Class_B_Dist.pdf LM4702 driving the MOSFET output power buffer http://www.national.com/an/AN/AN-1645.pdf |
#5 |
Are there any new commercial products (except Class-D) that match the sound character of class a (at least nearly) ??
#6 | |
UniGaBuf, a follower cut out to be a leader. I have another contender, a sliding class A circuit, but the Iq is ~180mA. |
#7 | |
#8 |
#9 | |
Exactly.
Thank you for this circuit - I will check the circuit in my CAD programm, If I have time. Last edited by tiefbassuebertr; 23rd March 2011 at 03:16 PM. |
#10 |
ClassAB with bootstrap will have 10kHz sounds better than 6kHz. In high quality classA, 6kHz beautifully beat 10kHz and everything sounds beauty and real. I found it when play with damper characteristics.
ClassA drop characteristics has major cause. When classA using huge feedback to achieve lowest distortion, that drop characteristics is gone, and it sounds like common amplifier. I post some picture here, may help too. Alternative topologies post#30 |
| low crossover-distortion class AB output stage topologies | capslock | Solid State | 70 | 21st February 2012 01:35 PM |
| Class A does sound better! | BrianEno | Pass Labs | 42 | 29th September 2007 02:45 PM |
| The best sound on the class D | felixx | Class D | 11 | 28th December 2006 10:07 PM |
| class B and AB idle current | demons_wing | Solid State | 6 | 6th October 2004 05:14 AM |
| Page generated in 0.17554 seconds (85.92% PHP - 14.08% MySQL) with 11 queries |
