h900
APEX H900 pdf file
sir the correct pcb design of h900
a say this because i see two design.
pls .... tell me which is right is right
and tell me what is the difference between h900 & h900 v2
pls reply me i am wating..............
same problem in both channel
hi mkubawat,
did u found the problem.?
thank u very much sir.....STEP 1:
A = 4.5 inch = 11.43 cm;
H = 3 inch = 7.62 cm.
STEP 2:
Then calculate the coefficient a = A / 6 = 1.9 cm.
STEP 3:
After step 2 is calculated active section of the core:
- first: b = 2 *a = 3,8 cm;
- second: S = b * H = 3,8 * 7.62 = 28.95 cmp (square centimeters).
STEP 4:
Now calculate the apparent power of the transformer (primary winding):
P1 = S * S = 28.95*28.95 = ~850VA.
Efficiency of such a transformer is about e=85%. In this case secondary power will be:
P2 = P1*(e/100) = 0.85*850 = 722.5VA.
STEP 5:
Knowing secondary electrical transformer voltages we can determine secondary winding current value using the following formula:
I2 = P2 / U2.
For example, you have two DC voltage of 100V (filtered with capacitors). Now, I refer to a symmetrical voltage of + / - 100Vdc, this means 200Vdc. The secondary voltage will be effective:
Vs = 0.707 * 200 = 141.4 VAC.
In this example, the secondary winding current will be maximum:
Is = P2 / Vs = 5.1 A.
So, if those 141.4 VAC are given by two voltages of about 70V each then current calculated above will be given by each winding.
I hope you understand me and I hope I was helpful.
hi apex sir,
here is h900.
supply dc votage is 100-50-0-50-100. sound is excellent.
one question , without load i increase the volume ,and i see the clipping led is blink, but i checked the out with dmm ,ac voltage is 26vac. is there any mistakes from me.
thanks.
one question for tony, can u tell me what is the exact ampere of this transformer.
40 into 4 transformer,
core size is 40mm by 79mm.
thanks
Nice work. DMM can measure only 50Hz sine wave ac voltage, you need scope for ac measurements.
question about resistors getting hot
Dear Sir Apex,
Just I want to ask if it is normal that these resistors with the red arrows are getting really hot.
2.2k 2 watts very hot
22k 1 watt very hot
3.3k 1 watt very hot
6.8k very very hot, it is like you will get burn if you touch it with in 1 0r 2 seconds
but the sound is very clear with good bass and treble, I'm using a full range Jamo S606 tower speakers for sound test.
the supply voltage are: 112 - 56 - 0 - 56 - 112 Volts DC from 40 40 0 40 40 Volts AC
Dear Sir Apex,
22k 1 watt very hot
Dear Sir Apex,
22k 1 watt very hot
This resistors must be hot, it's normal don't touch it
h900 & h900 v2 is all correct the difference is type of diode v1 is using two pin diode and v2 is using 3 pin diode
thanks mrching..............
i newly start that so i dont have much knowledge........... ones again thanks..... for guiding me,.............
regards............,,,,,,,,,
not yet. if you found then tell mehi mkubawat,
me also same problem.
not yet found.
Sir apex, hard to find IR2117.
If i use step driver of QSC RMX2450 using LM311, it is good for H900?
Can you post another Version of H900 using this step driver to all DIY. Thanks
Brod check post 1919 for transistor step driver.
Link: http://www.diyaudio.com/forums/solid-state/162408-900w-h-class-pa-amp-limiter-192.html#post2892341
regards,
mj777
- 900W H-class PA Amp with Limiter
