900W H-class PA Amp with Limiter - Page 85 - diyAudio
Old 18th October 2010, 08:01 PM   #841
apexaudio's Avatar
Originally Posted by dexter2003 View Post
are these diodes SF3006PT good for vertex2500?
Yes, use it in parallel.
Old 18th October 2010, 10:41 PM   #842
@ sir apex
sir can u send me a copy of your vertex amp i'm very interested to that monster amp... rolagaz_dumaguete@yahoo.com
Old 19th October 2010, 03:28 AM   #843
andrewlebon's Avatar
hi apexaudio
greetings just want to confirm a few things
1 R 100 is .47 ohms R52 4.7 ohms should be of same value what is correct value
2 how to identify 1 WATT RESISTANCES in vertex schematic i am thinking
longer resistances with no markings in resistor symbol is 1 WATT the smaller
resistor symbols have a dash in them is .25 watt can you please help out
thanking you
andrew lebon
Old 19th October 2010, 10:44 AM   #844
Originally Posted by andrewlebon View Post
hi apexaudio
thanking you
andrew lebon
hi andrew can u share the vertex schematic diagram,,,,,
Old 19th October 2010, 01:32 PM   #845
witch one of these tranzistors should i use
the original schematic is with 3x IRF2807
i found then , they are cheap ...
but insted of them can i use 2x IRF3808 ...tehy have bigger imput capacitances.....(
or 2x IRF140 ?
probably i will stick with the schematic
Old 19th October 2010, 03:35 PM   #846
A square's Avatar
Send a message via Yahoo to A square
Default pls chek my h900 PCB,s
pls chek PCB,s ....
nd pls chek heatshink for 2 ohm lord at 55v-110v..????
jon
Old 19th October 2010, 03:38 PM   #847
A square's Avatar
and any replacement for bav21 ?????
jon
Old 20th October 2010, 07:57 AM   #848
apexaudio's Avatar
Many interest for VERTEX amplifier, I will share schematic for DIY with notification soon.
Old 20th October 2010, 07:59 AM   #849
apexaudio's Avatar
Use MUR120 instead BAV21. With two fan cooling your heatsink is OK.
Old 20th October 2010, 09:21 AM   #850
apex,
count me in for vertex
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 9th July 2009 11:05 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
