900W H-class PA Amp with Limiter - Page 62 - diyAudio
Old 20th June 2010, 02:00 PM   #611
apex,
is this circuit same as h1200?
Old 20th June 2010, 02:04 PM   #612
apexaudio's Avatar
Originally Posted by engel dela pena View Post
apex,
VERTEX is H2500,
Old 20th June 2010, 03:23 PM   #613
andrewlebon's Avatar
hi apexaudio
greetings how many watts is this circuit can you tell me answer of this
question for general knowledge
1 10 pairs of 2sc5200 2sa1943 at 70 0 70 volt dc how much rms output power will be
produced emitter resistance .22 5 watt
thanking you
andrew lebon
Old 20th June 2010, 05:26 PM   #614
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apexaudio
thanking you
andrew lebon
With 70-0-70V DC you can get about 130Vpp or 46v rms, output power will be 530W on 4R load,
Old 21st June 2010, 03:33 PM   #615
apexaudio's Avatar
With 150-100-50-0-50-100-150V DC 2500W/4R
Old 21st June 2010, 05:33 PM   #616
eesbiboi's Avatar
this vertex/h2500 really hurts a lot...
Old 22nd June 2010, 08:55 AM   #617
VERTEX is H2500,
apex,
does a14
b250
b500
h750
h900
h1200
h2400
use same voltage amflification stage?
Old 22nd June 2010, 08:57 AM   #618
apex,
why you do not use tlo72 or ne553_ on vertex front?
Old 22nd June 2010, 10:44 AM   #619
apexaudio's Avatar
apex,
VERTEX use OP for DC servo, I want simetrycal input stage like in my MOSFET Amplifier with IRFP240/IRFP9240,
Old 22nd June 2010, 11:20 AM   #620
hi apexaudio
greetings is the 2500 watt circuit for diy understood no pcb for
this project can 2sc5200 be used in output stage for same power reason i ask
in my city for one pair ofmjl4281 we can buy 7 pairs of 2sc5200
1 is it 2step or 3 step voltage supply for 2500 watt circuit
2 you told me with 50 100 150 50 100 150 supply it is possible to get 2500
watts from 10 pairs of 2sc5200 3 step hclass
any schematic for diyers no pcb no problem can make pcb with hand
thanking you
andrew lebon
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 9th July 2009 11:05 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
