Old 9th May 2010, 02:45 PM   #531
apexaudio's Avatar
Originally Posted by khalsa View Post
Hi apex i am using ssh70n10a mosfet it contans 70 ampere 100volt.
Blue wire in input ground. i connect direct to the PCB.
Output is clear no problem.
plz chk this out.
Khalsa
Remove blue wire, and connect wire from psu gnd to signal input cinch gnd.
Old 12th May 2010, 12:30 AM   #532
andrewlebon's Avatar
hi apexaudio
greetings amplifier rocking want to finish packing it
1 are 10 10000 uf condensers for i channel or both
2 any preamplifier with base treble for this amplifier
will mj 15024 mj15025 increase power and safety 4 pairs will sound quality
be same
3 can you please tell me torridal diameter and height dimensions powering
both channels
thanking you
andrew lebon
Old 12th May 2010, 06:09 AM   #533
electra_ina's Avatar
For my project H900..I now still waiting IR2117...If H900 completed, I will share picture my project...
Old 12th May 2010, 08:30 AM   #534
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apexaudio
be same
both channels
thanking you
andrew lebon
1 PSU PCB with 8x10000uF is for stereo
2 I suggest only power amplifier in case, and preamp, mix, x-over... in another case.
3 Torridal diameter 200mm height 80mm for stereo amp in 2U case.
Old 12th May 2010, 02:46 PM   #535
apexaudio's Avatar
[QUOTE=
be same
[/QUOTE]
Yes sound quality will be same (best sounding PA amp I ever heared)
Old 13th May 2010, 10:59 PM   #536
qsa is offline qsa  Germany
qsa's Avatar
@apexaudio
how do you think about this simple linear Class H BJT Step driver circuit is this PA Amp ?
is it possibile to use this linear Class h Step Driver in quasicomplementary output stage too ?
without known problems compare to switching Class H Step Driver with IR2117 IC and Mosfets ?
Old 13th May 2010, 11:32 PM   #537
apexaudio's Avatar
Originally Posted by qsa View Post
@apexaudio
Try to find schematics or service manuals of some commercial PA amplifier with quasicomlementary nmos output stage (AB or H class), if this amplifier exist you can see solutions for your amp.
Old 14th May 2010, 12:52 AM   #538
qsa's Avatar
yes this Amplifier exist, have working some years ago for this company and sold a lot of pcs. from this model to european PA clients,
but heavy analaog amplifier is since 3 years obsolet in market by european clients.... and my previous factory dont have since today SMPS, this model dont like continous maximum Subbass output power, output devices can failed.
I dont like BJTs in output stage against bad experience, often different BJT amps failed with continous high output power
with hundreds of Class D and 50 pcs. sample NMOS amps +/- 100 V Rail no known problems compare to BJTs amps
very popular is class D in market.....class H with SMPS is popular too,... but not so much like class D
to find PRO AUDIO quasicomlementary nmos output stage (AB or H class) is really impossibile often amplifiers use BJT because this devices much more cheaper to produce amplifier,
Old 14th May 2010, 09:05 AM   #539
apexaudio's Avatar
Development amplifier from zero is difficult, I suggest to use reable solution from brands, I am not sure that the prise is a reason to not use that topology by brands.
Old 14th May 2010, 11:53 AM   #540
Workhorse's Avatar
EAW and ECLER uses NVMOS in their amplifiers
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 9th July 2009 11:05 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2013 diyAudio
