900W H-class PA Amp with Limiter - Page 52 - diyAudio
Old 5th May 2010, 01:10 AM   #511
electra_ina's Avatar
Hi Apex..can I used TR Sanken 2SA1494/SC3858 instead SA1943/SC5200 to high output PA?
Old 5th May 2010, 01:23 AM   #512
andrewlebon's Avatar
hi apexaudio
greetings completed amplifier sucessfully great detailed sound
very powerful amplifier very sweet sound .THANKS for your schematic and
COOPERATION all the way otherwise this great amplifier would not have
been possible no heating problems today i will make dc protector
1 can i put 4 pairs more on same heat sink would it result in more power in 4
ohms do not want to run amp in 2 ohms
2 mj 15024 15025 available but i suspect fake transistors
THANKS once again apex audio one more milestone crossed
DIYERS TRY THIS AMPLIFER
thanking you
andrew lebon
Old 5th May 2010, 08:59 AM   #513
apexaudio's Avatar
Yes, but not can be on this pcb (larger case).
Old 5th May 2010, 09:00 AM   #514
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apexaudio
thanking you
andrew lebon
Great news,
Old 5th May 2010, 09:29 AM   #515
Thanks Apex..How much power will carring out with 4 pair SA1494/SC3858? more than 500watt/4ohm?
Pozdrav..
Old 5th May 2010, 09:34 AM   #516
apexaudio's Avatar
Pozdrav..
B500 can produce 650W maximum,
Pozdrav..
Old 5th May 2010, 09:40 AM   #517
apexaudio's Avatar
hi apexaudio
thanking you
andrew lebon
H900 can have 1200W maximum on 4R load.
Old 5th May 2010, 09:47 AM   #518
Hvala unapred....
Yes..I mean with B500...
More question: For PSU H900, in my place very hard to find transformator 40vac-40vac-0-40vac-40vac. Can I used 2 trafo CT 42vac? Please help me with diagram.
Regards..
Old 5th May 2010, 09:55 AM   #519
apexaudio's Avatar
Hvala unapred....
Regards..
Yes, you can connect primary in parallel, and secundary in series. Conection beatwin secundary will be CT, and you have 2x84vac at the end of secundary.
Old 5th May 2010, 10:07 AM   #520
Thanks alot Apex...Yes I undestood..If each trafo 10 Ampere, what 2 trafo will be 20 Ampere or 84vac x 20 A = 1680 watt??
Pozdrav..
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
