900W H-class PA Amp with Limiter - Page 261 - diyAudio
Old 3rd October 2013, 10:40 AM   #2601
vedmitraa's Avatar
My e mail Mr. wiljj78, vedmitraa@gmail.com
Failure in Experiment is key to success .Only right combination is needed.
Old 3rd October 2013, 10:51 PM   #2602
Originally Posted by wiljj78 View Post
File sent...
Thank You so much Mr.Wiljj78.
Regards.
Old 4th October 2013, 02:18 AM   #2603
Hi, I have several designs gyh class, my email is jluis.hp @ gmail.com
Old 4th October 2013, 02:46 AM   #2604
also have some of 2000w to 5000w? class g and h?
Old 7th October 2013, 05:27 AM   #2605
Hi, can you send me design of class h and g. My email iiee3602@yahoo.com.ph
Old 7th October 2013, 05:36 AM   #2606
Hi, can you send me of class g and h design. thanks!
Old 24th October 2013, 10:05 AM   #2607
Hi everaone
I am new on this forum and I want to ask some questions.
Somebody tried to make power supply for APEX H900 with voltages 100VAC-50VAC-0-50VAC-100VAC???
I have transformer with those voltages and want to use it for this amp if it is possible.
I know that is pretty high but I just want to know if somebody tried to do this?
Old 26th October 2013, 01:12 PM   #2608
apexaudio's Avatar
Originally Posted by antonamp View Post
Hi everaone
H900TEF with add more outputs can use PSU with this voltages.
Old 28th October 2013, 08:28 AM   #2609
I found the old transformers with voltage 35Vac-0-35Vac and I'll use them. I have two of the same so that the power problem solved. All I care about how much power your amplifier with a voltage of 70VAC-35VAC-0V-35VAC-70VAC??? Thank you.
Old 30th October 2013, 02:01 AM   #2610
jaagut is offline jaagut  Philippines
allow to me to try.
if transformer has 70Vac, in reality when connected to a load, this voltage will sag, let's say by 10% regulation, to 63Vac.
according to Mr Ohms, P = V*V/R, therefore
for 8 ohms load, P = 63*63 / 8 = 992W
for 4 ohms load, P = 63 * 63 / 4 = 1984W
however, Class H amp usually has efficiency of let's say 78%, therefore
for 8 ohms load, 992W * 78% = 774W
for 4 ohms load, 1984W * 78% = 1548W
(correction is welcome, if any. thanks.)
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 10th July 2009 12:05 AM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright 1999-2017 diyAudio
