900W H-class PA Amp with Limiter - Page 235 - diyAudio
Old 1st December 2012, 04:03 PM   #2341
DAMANHURI's Avatar
Originally Posted by wiljj78 View Post
Hello Damanhuri,
Try to jump 1 of your AC line from protect AC supply to pro terminal that should deactivate the relay.
regards,
18 AC line or from the main supply 55 AC? connected to the point of pro?
Best regards - Damanhuri
Old 1st December 2012, 04:07 PM   #2342
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Yes, the 18VAC line that supplies on your protect board itself.
Old 1st December 2012, 04:23 PM   #2343
DAMANHURI's Avatar
OK Sir, i Try tomorrow
Old 1st December 2012, 05:18 PM   #2344
hi apex sir ,
is this three step power supply correct?,
compare to ur schematic.
Old 2nd December 2012, 05:54 AM   #2345
hi apex sir,
can u tell me the 10000u/ 100v caps safe. because this 100v caps directly connected to the gnd.
Old 2nd December 2012, 10:44 AM   #2346
The 50Vdc from 35Vac transformer varies with mains voltage. This applies when regulation ~4%
It can be as low as 48Vdc and as high as 53Vdc
If you double this from a 70Vac tapping then the maximum voltage could be as high as 106Vdc.
If regulation is >>4%, then the worst case highest voltage can be >>100Vdc
I would not do that !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd December 2012, 11:37 AM   #2347
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi Send a message via Skype™ to rizqi
Thumbs up h900 v.2
Hello Rizqi,
Thanks.. This design have not been tested yet i'm still trying to find some error before i etch, but you can also review and let me know if you found any mistake so i can correct the error.
Send me your email add so i can forward you the sprint layout file.
i've cek your layout, thats nice n good layout, so there are more space for some component. your layout has true.. please send to : ugho_mdlx@yahoo.com
good job sir,...
thanks n regards
Better try it ...
Old 2nd December 2012, 03:05 PM   #2348
hello sir can any share amplifier bridging circuit
Old 2nd December 2012, 04:06 PM   #2349
wiljj78's Avatar
good job sir,...
thanks n regards
File sent, please check your mail.
Old 2nd December 2012, 07:38 PM   #2350
wiljj78's Avatar
Rizqi,
Please dont forget red Jumper.
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
