900W H-class PA Amp with Limiter - Page 234 - diyAudio
Old 28th November 2012, 08:10 PM   #2331
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Default My APEX H900 Ver.2
I would like to build APEX H900 Ver.2
Thank you Mr. Mile for sharing this class H amp...
Wiljj78
Old 29th November 2012, 12:16 AM   #2332
andrewlebon's Avatar
Default HELLO
Driver stage on H900 work with +/-120V DC, only output stage work with /-60V DC and step to +/-120V DC in peaks.
Hi Apexaudio
greetings my mistake can output stage be modified to 70 - 75
volts dc want to try with TEF its still my favourite amp
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 29th November 2012, 06:04 AM   #2333
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi Send a message via Skype™ to rizqi
Hello sir mile, Iwould build an amp for home teather. Amps are the masters recommend?can I use H900 for main sytem.? Do you have recomendationsfor me?
Better try it ...
Old 29th November 2012, 06:29 AM   #2334
rizqi's Avatar
Wiljj78
Nice design sir....
Would u shared me with sprint layout ver.?
Thanks n regards...
Better try it ...
Old 29th November 2012, 06:47 AM   #2335
DAMANHURI's Avatar
Originally Posted by rizqi View Post
Nice design sir....
Thanks n regards...
I do not use Sprint layout software.
Best regards - Damanhuri
Old 30th November 2012, 10:26 AM   #2336
apexaudio's Avatar
Originally Posted by DAMANHURI View Post
many thanks to the APEX
I tried to make a video to share.
regards
APEX AUDIO PROTECTOR - YouTube
Nice work, I suggest to warm up TIP31C to test high speed fan and thernal protect, also you can connect AC to PRO input and test overload protect (must be power off reset).
Old 30th November 2012, 12:15 PM   #2337
princenk007's Avatar
Oops.. my bad..I just happened to push the drivers with a bit more bass and the coils got toasted... I also forgot that my traffo was over sized and did not use apex protect .
Apexaudio or Andrew T or someone could please add a 50Hz low cut filter to the Amp input please .. It can be a little upgrade to the amp..
Old 1st December 2012, 03:05 AM   #2338
DAMANHURI's Avatar
I've tried to use Solder TIP31C transistor to heat and measure the voltage coming out in the Fan and the result output Voltage grow up, but I have not found a way to determine the point of PRO (Short Protection) to work without having to use the Power Amp.
regards
Old 1st December 2012, 05:14 AM   #2339
wiljj78's Avatar
Hello Damanhuri,
Try to jump 1 of your AC line from protect AC supply to pro terminal that should deactivate the relay.
regards,
Old 1st December 2012, 05:20 AM   #2340
wiljj78's Avatar
Nice design sir....
Thanks n regards...
Hello Rizqi,
Thanks.. This design have not been tested yet i'm still trying to find some error before i etch, but you can also review and let me know if you found any mistake so i can correct the error.
Send me your email add so i can forward you the sprint layout file.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 9th July 2009 11:05 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
