900W H-class PA Amp with Limiter - Page 233 - diyAudio
Old 25th November 2012, 08:06 AM   #2321
hi apex sir,
is this correct sir h900 tef?
Old 26th November 2012, 12:07 AM   #2322
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi Send a message via Skype™ to rizqi
@damanhuri...
Ok... thanks brow...
Sipp
Salam kenal yah?..
Better try it ...
Old 26th November 2012, 12:08 AM   #2323
rizqi's Avatar
Hy nazir...
Cek u'r email...
Better try it ...
Old 26th November 2012, 02:01 AM   #2324
DAMANHURI's Avatar
Originally Posted by rizqi View Post
@damanhuri...
Sipp
Salam kenal yah?..
OK Bro, sama2.
I've finished Protect speaker and it worked fine. I'm so glad for this. Thanks APEX
Best regards - Damanhuri
Old 27th November 2012, 12:30 AM   #2325
rizqi's Avatar
Default Mbokan wis genah layout e?
Originally Posted by nazirdigi View Post
hi apex sir,
why? ... you can not use the basic scheme or drawing paths from the apex B500 series or H900?
you just change the bias section only.
for steper you can see on the H900, then adjust the TEF scheme that I send.
Better try it ...
Old 27th November 2012, 03:27 AM   #2326
andrewlebon's Avatar
Hello Apexaudio
greetings can h900 driver stage be modified to 70 volts dc +/- to
get more power using TEF with 8 pairs its a wonderful amp
warm regards
andrew
"It's Better to try and fail than to never know and always wonder"
Old 27th November 2012, 04:02 AM   #2327
rizqi's Avatar
Default Make a NSL-
Originally Posted by aman khalsa View Post
hello sir
i m trying to make NSL32 .i use simple LDR nd LED..is this ok???
thank u
how mach value for NSL ? are 32k?? so where A and K conect to main PCB?.. can u spesific about your made for that?
regard
Better try it ...
Old 27th November 2012, 04:23 AM   #2328
DAMANHURI's Avatar
regard
I never use NSL32
Old 27th November 2012, 07:58 AM   #2329
apexaudio's Avatar
Originally Posted by andrewlebon View Post
Hello Apexaudio
warm regards
andrew
Driver stage on H900 work with +/-120V DC, only output stage work with /-60V DC and step to +/-120V DC in peaks.
Old 28th November 2012, 04:41 PM   #2330
DAMANHURI's Avatar
Thumbs up Protect my second
many thanks to the APEX
I tried to make a video to share.
regards
APEX AUDIO PROTECTOR - YouTube
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
