900W H-class PA Amp with Limiter - Page 201 - diyAudio
Old 17th March 2012, 08:22 PM   #2001
hi apex sir,
can i use mur1660ct instead mur1620ct for h900v2?
Old 19th March 2012, 01:37 AM   #2002
mj777, ask lang for any substitute of MUR1620 and BAV21. Hard to find here in iloilo city.
Old 21st March 2012, 06:30 AM   #2003
hi apex sir,
pls, reply to post no-2001.
Old 21st March 2012, 07:09 AM   #2004
Originally Posted by nazirdigi View Post
hi apex sir,
you can use it, but i think for better result you should use mur1620 because its reserve recovery time less than mur1660.
Old 21st March 2012, 11:19 AM   #2005
because 1660ct is cheap than 1620ct, 40rs- 1660ct, 1620ct- 120rs.
1/3 cheaper.
Old 21st March 2012, 07:02 PM   #2006
apexaudio's Avatar
hi apex sir,
Yes, but you can use many other TO220 dual diode also.
Old 22nd March 2012, 06:51 AM   #2007
thanks apex sir for the reply, very helpfull.
Old 23rd March 2012, 04:57 AM   #2008
hi apex sir,
can i use MUR120 instead bav21 for h900 ?
what should be change in step drive for 120-52-0-52-120 DC supply
Old 23rd March 2012, 10:11 AM   #2009
apexaudio's Avatar
Originally Posted by mkubawat View Post
hi apex sir,
MUR120 can be use instead BAV21, and no changes for 120-52-0-52-120 DC supply
Old 23rd March 2012, 12:23 PM   #2010
Thanks a lot for quick reply
with this supply(120-52-0-52-120DC) both rail stepping properly according to signal(gain), but found clipping when voltages start stepping to higher rail.voltages swings between 50 to 80v both rail.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 10th July 2009 12:05 AM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright 1999-2017 diyAudio
