900W H-class PA Amp with Limiter - Page 200 - diyAudio
Old 15th March 2012, 07:57 AM   #1991
mj777, can i replace IRF2807 with IRF540 in transistor type step driver of H900?
Old 15th March 2012, 08:05 AM   #1992
electra_ina's Avatar
iiee...
IRF2807 used for max voltage 75vdc
IRF540 max voltage 100v
Old 15th March 2012, 08:33 AM   #1993
Default Transistor stepdiver
So there is no question to replace IRF2807? In our place, hard to find this trans.
Old 15th March 2012, 12:05 PM   #1994
You can use 2pcs. IRF540 per rail instead IRF2807
Old 16th March 2012, 12:19 AM   #1995
Smile Transistor stepdiver
Thanks for that sir.
Old 16th March 2012, 01:07 AM   #1996
This 2 module of H900 with discrete step driver use 2 IRF540 per rail without any problem encountered
power supply used is +/- 110-55-0-55-110 volt
Old 16th March 2012, 09:21 AM   #1997
AndrewT is online now AndrewT  Scotland
irf540 are 100Vds devices.
How do you make them reliable with a +-110Vdc supply?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th March 2012, 07:36 AM   #1998
Hey AndrewT look at this original schematic of H900 and ask apex and others who build this amp why they use IRF540 at +/- 120-60-0-60-120 volt rail
Old 17th March 2012, 07:43 AM   #1999
TonyTecson's Avatar
irf540 while supplied from 120volt supply sits atop 60volts.....if Apex is confident with them, you can use them...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 17th March 2012, 08:16 AM   #2000
apexaudio's Avatar
On IRF540 is only 55Vdc.
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
