900W H-class PA Amp with Limiter - Page 185 - diyAudio
Old 16th January 2012, 10:56 AM   #1841
balanced input bx500
Old 16th January 2012, 12:28 PM   #1842
apexaudio's Avatar
This is BX500 with balanced input, your schematic is only for bridge two amp channels.
Old 17th January 2012, 12:41 AM   #1843
sir mile,
can you just clear once,andrewt issue of R23 and biasing
the 4 pair h900 is pre bias with resistor,how is it this time guys are following 3 ef,nazirdigi 5 pair and how about soerdjanto,all in all please guide us in biasing 3 ef
Old 17th January 2012, 03:51 AM   #1844
Hi Apex,
- Can i replace SFA1603 with BYW 29/100?
- Can i replace BAV 21 with BY 299?
Tx,
Regards....
Old 17th January 2012, 01:43 PM   #1845
andrewlebon's Avatar
Default TEF H900
Follow schematic with darlington BD681 and 10k preset for biasing, and I suggest balanced input like in BX500 with volume pot.
___
Hi Apex audio
greetings any particular reason for using BD681 AND balanced input
like BX500 in TEF H900 and is it safe at 70 and 120 volt dc supply rails please
what will be power in 4 ohms and 2 ohms load thinking of making it
warm regards
andrew lebon
Old 17th January 2012, 05:41 PM   #1846
apexaudio's Avatar
Originally Posted by Suluh Wibowo View Post
Hi Apex,
Tx,
Regards....
It's easy to find replaces, use google
Old 17th January 2012, 05:46 PM   #1847
apexaudio's Avatar
sir mile,
If you can't set bias R23 relace with 7k5.
Old 17th January 2012, 05:49 PM   #1848
apexaudio's Avatar
___
Hi Apex audio
warm regards
andrew lebon
I not suggest to use 2 ohms with 4 pairs, on 4 ohms 1200W is maximum power.
Old 17th January 2012, 07:12 PM   #1849
Finally, accepting that 15k for R23 in that post does not allow the correct range of bias voltage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th January 2012, 07:50 PM   #1850
apexaudio's Avatar
My mistake, for B500 and H900 R23 is 15k, but for B500TEF and H900TEF R23 is 7k5.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 10th July 2009 12:05 AM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright 1999-2017 diyAudio
