900W H-class PA Amp with Limiter - Page 183 - diyAudio
Old 14th January 2012, 12:27 AM   #1821
andrew
dont forget to put bias control
bias trimer
Old 14th January 2012, 12:33 AM   #1822
andrewlebon's Avatar
Default bias control
Hi Engel Dela Pena
greetings please can you give me pages of TEF STAGE on h900
thread and post where sir apex audio showed where to put preset
warm regards
andrew lebon
Old 14th January 2012, 01:04 AM   #1823
andrew
bias control
Old 14th January 2012, 01:05 AM   #1824
tripple ef
Old 14th January 2012, 01:13 AM   #1825
Default thanks
i start pcb on sunday
Old 14th January 2012, 03:22 AM   #1826
you can use irvynjay lay out of step
regards
Old 14th January 2012, 04:05 AM   #1827
Default POST 1823
how did BD 681 COME its darlington transistor i think final pcb design be like soerdjanto TEF PCB but no protection on pcb
warm regards
andrew lebon
Old 14th January 2012, 10:11 AM   #1828
post1823
R23 must be wrong. 2k2 could be a better value.
The Vbe multiplier output voltage should be around 2400mV, when output bias is set 5mV.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th January 2012, 02:44 PM   #1829
apexaudio's Avatar
Originally Posted by AndrewT View Post
post1823
R23 is OK, the Vbe multiplier output voltage with darlington should be around 3600mV max.
Old 14th January 2012, 03:45 PM   #1830
my oops.
The Vbe multiplier voltage should be around 3600mV.
R23 is still wrong.
regards Andrew T.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 10th July 2009 12:05 AM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright 1999-2017 diyAudio
