900W H-class PA Amp with Limiter - Page 175 - diyAudio
Old 11th December 2011, 08:52 AM   #1741
ChingTan's Avatar
Send a message via Yahoo to ChingTan
Originally Posted by nazirdigi View Post
Hi apex sir,
pls can u check this power supply pcb board is correct for h900. i draw from the scematic.
because of the capacitor size, i bought capacitors and not fit to Ur psu baord, so thats why i design this pcb.there are series in caps. 2 into 10000 in series reduced to 5000uf or can u explain.
obviously correct
Old 11th December 2011, 08:58 AM   #1742
Originally Posted by mrching View Post
obviously correct
thanks for reply mrching.
but 2 10000uf caps in series reduced to 5000uf, is it correct?
Old 11th December 2011, 09:04 AM   #1743
apexaudio's Avatar
Yes, but maximum voltage increas to 126V
Old 11th December 2011, 09:20 AM   #1744
thanks for reply sir.
so in this situation is this power supply enough to run two channels of h900.?
Old 12th December 2011, 07:25 AM   #1745
dearsir
i want step draver pcb layout this amp
pb
Old 13th December 2011, 04:29 PM   #1746
Do you have two channels (boards)? Post better pictures and some measurements.
Dear Apex, thanks for reply
yes i have two channels but i test one by one with one 750va transformer , voltage at DC side 110-56-0-56-110 , clipping found when voltage try to step to high rail(voltage measure at both fuses +/- 58v to 65 when clipping)
I use uf4007 instead of BAV21 & MUR1560 in circuit.
sorry for poor english
Old 18th December 2011, 03:28 AM   #1747
hi apex sir,
is it possible to get 1400w into 2ohm in h900, any changes in h900 pcb?
Old 18th December 2011, 09:41 AM   #1748
apexaudio's Avatar
Test second channel, and compare if there is differences...
Old 18th December 2011, 09:47 AM   #1749
apexaudio's Avatar
hi apex sir,
I can't suggest to use H900 with 2R load, but many brand class H amps with 4 pairs of outputs suggest 2R load (crown, QSC...).
I suggest H900 with 7 pairs of outputs for 2R load.
Old 18th December 2011, 11:04 AM   #1750
ok i edit the h900 v2 for 7pair.
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
