900W H-class PA Amp with Limiter - Page 151 - diyAudio
Old 31st July 2011, 08:37 AM   #1501
aman khalsa's Avatar
Default nice work sir..
Originally Posted by CHESHTAP View Post
hello sir...
very nice work sir can u pls post schematic ...
thank u ...
Old 31st July 2011, 11:16 AM   #1502
andrewlebon's Avatar
Default bias
hi chestap
greetings whats the bias voltage over emitter resistances and
bias prest 3k on driver pcb NICE WORK whats the power in 7 pairs
warm regards
andrew lebon
Old 31st July 2011, 11:25 AM   #1503
Hi cheshtap nice work
Can u post schematic of this amp ?
Old 2nd August 2011, 01:30 AM   #1504
Default CONNECTIONS
HI CHESTAP
greetings can you post connections to your driver pcb or schematic
it would make construction of amp easier hoping you can help out
warm regards
andrew lebon
Old 5th August 2011, 08:22 AM   #1505
HI CHESTAP
it would make construction of amp easier hoping you can help out only need connections of bridge how to wire them power pcb is almost ready
warm regards
Andrew lebon
Old 5th August 2011, 10:32 AM   #1506
STAGE4 is offline STAGE4  Sri Lanka
STAGE4's Avatar
Default bjt power amp class h
PLS CORRECT THIS..
Old 5th August 2011, 10:47 AM   #1507
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by andrewlebon View Post
HI CHESTAP
warm regards
Andrew lebon
is this the limiter ?
Old 5th August 2011, 11:27 AM   #1508
STAGE4's Avatar
CORRECTED.pdf
CORR.pdf
Old 5th August 2011, 12:37 PM   #1509
hi chestap,
do you have dil version.
just in case builder have dil type op amp
Old 5th August 2011, 03:11 PM   #1510
DEAR CHESHTAP
Please post schematic , if you have it.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 9th July 2009 11:05 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright 1999-2017 diyAudio
