900W H-class PA Amp with Limiter - Page 135 - diyAudio
Old 10th May 2011, 06:19 PM   #1341
khalsa is online now khalsa  India
Send a message via Yahoo to khalsa
HI soerdjanto your 2sa1943 collecter is attached with +ve side on mur1620 its wrong you will attached -ve side pls check schematic
Old 11th May 2011, 06:58 AM   #1342
Julio25 is offline Julio25  Philippines
Default power amp
anyone have a pcb component side for an xlr input?ive seen it in the thread but i cant remember where.
Old 11th May 2011, 04:53 PM   #1343
Is this correct Sir??
Old 11th May 2011, 08:22 PM   #1344
apexaudio's Avatar
R24 and R25 must be connect to +/-MV, add BAV21 in paralel with 100pF on drivers and it can work.
Old 12th May 2011, 02:09 AM   #1345
another H900 revolution,
this v. is good easy to find parts
how about the switching
will this be a better one?
Old 12th May 2011, 08:34 AM   #1346
Like this???
With only one mosfet on step driver,how much final transistor can be use???
Old 12th May 2011, 02:13 PM   #1347
apexaudio's Avatar
Like this???
This is OK, 4 pairs is maximum with this topology, for more outputs you must add predrivers (triple darlington) and more step mosfets.
Old 12th May 2011, 02:50 PM   #1348
Ok..thank you Sir....
Old 14th May 2011, 01:26 AM   #1349
sir mile,
if two mosfet should be use in 4 pair of output,how many mosfet in 6 pair,8 pair,how to determine step drive mosfets?
Old 14th May 2011, 08:04 AM   #1350
apexaudio's Avatar
Originally Posted by engel dela pena View Post
sir mile,
Use 2, 3 or 4 IRF540 mosfets, IRF2807 can be use for 4 outputs.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
900w amp module for sale nigelwright7557 Swap Meet 0 10th July 2009 12:05 AM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright 1999-2017 diyAudio
