900W H-class PA Amp with Limiter
Mr. Mile if i change the output transistor with mjl 21193 + 21194, is there any change with the pro circuit in attachment
The protect should only kick in at short circuit,, it's not SOA protection, therefore should be fine for your MJL21194s.
Thanks Vostro, just curious about apex protect because if i'm not wrong he ever said it's include over current protection, that's why i ask does changing the final transistor affecting to overcurrent protection, but i'm newbie corious to know what is the pro circuit send to the protect kit? that's my 2nd question :eek: sorry OOT n my bad english
Hi sandman15th sir do you have bav21 and sfa1630 if yes were did you get it? Im planning to build h900 too but i dindnt get those part here in phil.thanks kabayan merry christmass
Sent from my GT-S7562 using Tapatalk
hi eit, next week i go to electronic supply here in riyadh,i will look there.if i cant find,any replacement of bav21 and sfa1630? but ir2117 i have already 4pcs. =( cost me 30 sr each, almost 350 pisos).. merry christmas..=) cheers:D
I got also ir2117 40 peso each here in ph but bav21,&sfa1630 no where cant find here
