900W H-class PA Amp with Limiter
Old 22nd November 2010, 12:36 PM   #971
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by ravslanka View Post
hi apex
iam planning to make h900 please check the pcb layout .i have widen the tracks as pcbs
availability is of very poor quality.and also can 2 parallel 15 volts zener be used instead of 1 zy15.polarity of bf422/423 is changed will correct it.thanks in advance.
http://img526.imageshack.us/img526/8438/39092467.gif
ravs
be a vegeterian.....
I suggest to use +/-MV and 1k/2W instead 6k8/2W to get +/-15V for ICs,
Nice pcb, do you use coolets pcb as start point?
Old 22nd November 2010, 05:05 PM   #972
ravslanka is offline ravslanka  India
hi apex,
will do so as you suggest did you find any other error.and also can two 1 watt
zener be used instead of 1 2watter.yes i used some part as a reference from his
pcb.ill start etching the pcb as soon as you verify it.
thanks
ravs
be a vegeterian......
Old 22nd November 2010, 06:23 PM   #973
sekhar is offline sekhar  India
to ravslanka (u have done a great job)
i just love ur layout , i am gonna use ur layout, i have attached the picture of ur pcb with a few red circles whr i think the traces should be a bit thin cause producing high resolution pcbs is nt always possible and there can be shorts , so if possible reduce the track size at the indicated positions ............. and can u add few more o/p transistors if possible just to be on the safe side.
regards
sekhar
Old 23rd November 2010, 12:03 AM   #974
apexaudio's Avatar
hi apex,
thanks
ravs
I will verify final pcb, what is pcb size.
You can use one 1W zener if you use +/-MV.
Old 23rd November 2010, 04:43 AM   #975
coolet is offline coolet
coolet's Avatar
for this monster amp you need a 1mm solid wire layed and soldered to the pcb track as shown in picture... light blue color traces.
Old 23rd November 2010, 09:20 AM   #976
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 900W H-class PA Amp with Limiter
Default pcb copper side
Hello can you pls share your pcb on mirror/ copper side I'd like to try your design
Old 23rd November 2010, 12:15 PM   #977
coolet's Avatar
post #659
500W PA amplifier with Limiter
Old 23rd November 2010, 01:35 PM   #978
engel dela pena is offline engel dela pena  Philippines
Originally Posted by Workhorse View Post
How much power do you want ?
With 2 step class-h with 1943/5200 pairs you cant increase your rails beyond 70VDC per step. Around 3.5kW could be manageable with 14-16 pairs at output for continuous duty cycle operation into 2 ohms.
h900v2 + another output pair
power is up to 3.5kw
File Type: png TOP%20%2B%20BOTTOM%20%20LAYER%20H900[3].PNG (25.6 KB, 1204 views)
Old 23rd November 2010, 02:29 PM   #979
miles what mosfet can replace irf540 that comes in plastic package like 2sc4793........??????????????????
regards
sekhar
Old 23rd November 2010, 03:06 PM   #980
irf640 is also a To220 device.
or do you mean Toshiba's 2-10R1A package?
regards Andrew T.
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
Copyright ©1999-2017 diyAudio
