900W H-class PA Amp with Limiter
Old 26th October 2010, 03:55 AM   #901
A square is offline A square  Australia
A square's Avatar
Send a message via Yahoo to A square
thanx sir
have a good day......
jon
Old 27th October 2010, 06:54 AM   #902
eesbiboi is offline eesbiboi  Philippines
eesbiboi's Avatar
Default output voltage swing
apex sir,
using the chart you post...
if your vertex amp is rated 2500 at 4ohms,...
does this mean it can dissipate up to 100v per channel???...
and up to 200v when bridged???...
pls correct me if i'm wrong...
tnx and regards...
ees...
Old 27th October 2010, 09:49 AM   #903
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by eesbiboi View Post
apex sir,
tnx and regards...
ees...
Yes, for 2500W/4R you need 100V RMS at the output, and +/-140V DC rail voltage in 2 or 3 step.
Old 27th October 2010, 01:02 PM   #904
eesbiboi's Avatar
thank you for the answer sir...
1 this means if i have a class aB amp with +/-100v psu, i would get maximum of 1250w at 8ohms disregard of all the losses i may have...
i just dont know how much efficiency class aB amps have...
2 in h class amps, i notice that adding step drivers to a class Ab amp adds more power to it,just like b500 and h900, how does step drivers help in adding more power to an amp???
3 are there possible ways{circuits} for step drivers that uses bjt's and easy to find ic's instead of mosfets and some rare ic's???..
thank you sir...
sorry for all these questions...for i am still in the process of learning...
regards...
ees...
Old 27th October 2010, 03:08 PM   #905
apexaudio's Avatar
thank you sir...
regards...
ees...
With +/-100V rail voltage power will be 625W/8R not 1250W.
CREST PRO 8001 use only BJTs for class H step driver.
Old 27th October 2010, 03:14 PM   #906
eesbiboi's Avatar
sir...
how did you arrive to that answer???...
i was completely wrong in my estimate...
thanks...
Old 27th October 2010, 03:22 PM   #907
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
900W H-class PA Amp with Limiter Send a message via MSN to AKN
Use RMS voltage instead of Peak voltage when you calculate power, i.e 100/sqt2
/ Anders
Old 27th October 2010, 03:32 PM   #908
A square's Avatar
Default hi
hello sir
what is BJT,s ....
thanx.....
jon
Old 27th October 2010, 03:50 PM   #909
coolet is offline coolet
coolet's Avatar
BJT = bipolar junction transistor
Old 27th October 2010, 04:00 PM   #910
A square's Avatar
hello coolet sir ......
nice to see u ....
thanx for info....
jon
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 10:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 03:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 07:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 05:30 AM
