900W H-class PA Amp with Limiter
Old 14th March 2010, 10:10 AM   #81
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by oldmaelstrom2 View Post
Step Driver schematic from Zeck Audio power amplifier PT series?
Yes, step driver from Zeck PT-9 upgrade with extra higher voltage fets.
Old 15th March 2010, 09:51 AM   #82
qsa is offline qsa  Germany
qsa's Avatar
will add Class H Step Driver in Quasis NMOS Amplifier schematic
after finished schematic will upload here, lets check for faults
hope it will work
Old 15th March 2010, 11:02 AM   #83
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default power amp
hi qsa
greetings how is power amp n mos sounding and stability
trying to make it but gerber files to complicated any new modifications
please let us know will keep trying as i have all components
thanking you
andrew lebon
Old 15th March 2010, 11:55 AM   #84
apexaudio's Avatar
hope it will work
I have no expirience with amplifiers in H or G class which using mosfet in output stage. With BJT have no problem.
Old 17th March 2010, 04:26 AM   #85
savu is online now savu  Ireland
savu's Avatar
Send a message via MSN to savu
Originally Posted by apexaudio View Post
Do anyone want to DIY something like that?
Hello apexaudio. I am concidering to DIY the amplifier after i will finish a 2KW SMPS project with my girlfriend (helping her to learn electronics for school). Thank you for the the PCB design.
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 17th March 2010, 10:36 AM   #86
hi apex audio
greetings pcb ready inserting components some pics
thanking you
andrew lebon
Old 17th March 2010, 11:24 AM   #87
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apex audio
thanking you
andrew lebon
Nice work, dont forget wire jumper.
Old 17th March 2010, 11:30 AM   #88
apexaudio's Avatar
I am interested about this 2kW SMPS, can it give 4x55V DC?
Old 17th March 2010, 09:19 PM   #89
savu's Avatar
the original schematic I will use actually delivers 2 x 60V dc. but it can be modified. i will keep you informed about the way things are going.
regards,
1'st rule of chess:
Old 17th March 2010, 09:28 PM   #90
apexaudio's Avatar
regards,
Then can be used two in series circuit
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
